Author Topic: These Cows Sure Have Some Oil Pressure!!!  (Read 3912 times)
« on: September 15, 2010, 08:43:45 PM »
I finally had time to hook up the oil pressure gauge this week.  I machined a "manifold" that screws into the block and has provisions for attaching the oil pressure switch and the fitting for the gauge's pressure line.
I then fabricated a little panel for the meter to attach to.  I ran the nylon line from the engine to the gauge inside some 1/4" polyurethane line to keep it from kinking and chafing.  Time will tell whether this will be durable enough and I may very well wind up at work some morning with oil all over me!
After hooking everything up I found I had around 75 psi at idle and around 4k I had 115 psi.  Of course, this was with cold oil but found I could "blip" the throttle and have the needle approach the 150 psi mark!!
I will ride this around until I can verify my oil light issue and then decide whether or not to leave it in place...
Re: These Cows Sure Have Some Oil Pressure!!!
« Reply #1 on: September 15, 2010, 09:30:29 PM »
That's pretty much what I've posted here a few times, 'Oak' Okleshen has said on a real cold day, that 165 psi oil pressure was possible !!!!
Pretty much explains the crushed oil filters .
What was the air temp then, around 75 F. ?
« Reply #2 on: September 15, 2010, 09:39:46 PM »
If this were to be a permanent install, would you use steel line, rather than the nylon?
« Reply #3 on: September 15, 2010, 09:40:19 PM »
Bob, these pictures were from this evening and probably 85 - 90 in the garage...
« Reply #4 on: September 15, 2010, 09:41:53 PM »
You probably won't see 75 until January, at least, eh Justin? ;)
« Reply #5 on: September 15, 2010, 09:43:07 PM »
Rob, in automotive applications I use copper tubing but since we have constant flexing in the steering head/neck area I don't know whether a solid line would live very long.  I may look into a steel-braided line...
« Reply #6 on: September 15, 2010, 09:44:19 PM »
A couple weeks ago it actually got down to 59 degrees one morning!  I damn near froze to death riding to work!  But the next week we were paying for it...
« Reply #7 on: September 15, 2010, 10:08:52 PM »
What weight oil is in the bike ?
« Reply #8 on: September 15, 2010, 10:35:53 PM »
Castrol GTX 20w50...  Once the new rings are broken in I'll probably switch it to Mobil 1 15w50...
« Reply #9 on: September 16, 2010, 10:31:51 AM »
So I guess when I leave the bike outside at work during the brief 'winter' we have here in Phoenix, I really need to keep the throttle usage to a minimum until the oil gets to 80-90 F.
Especially when I'm using 20w50 semi-synthetic oil all year long .
« Reply #10 on: September 16, 2010, 10:51:59 AM »
Same here.  I took it out for a freeway blast today and found then when fully warmed up I had 80 - 85 psi at about 85 mph.  Dropping backk down to 60 mph resulted in a reading that jittered around 65 psi - but no oil-light.  The needle reminded me of how a speedo reads out when the cable is on it's last legs.  I think I'm going to take a look at the filter...  I did a top-end job on this last winter and maybe crud has built up on the filter...
« Reply #11 on: September 16, 2010, 01:25:29 PM »
I would use the stainless goodridge line as on the front brakes.
« Reply #12 on: September 16, 2010, 03:03:33 PM »
Yeah, probably will order something like this kit:
http://www.summitracing.com/parts/SUM-G2960/?rtype=10
« Reply #13 on: September 16, 2010, 03:15:45 PM »
Any particular reason you didn't go with an electrical system, instead of a direct reading indicator ?
« Reply #14 on: September 16, 2010, 03:36:46 PM »
The electrical oil pressure senders are usually quite bulky so probably would have had to remote mount it, run plumbing, etc...  I figured the mechanical gauge would be simpler in the long run...  If I had a box full of braided line, AN fittings, etc, I might have done an electrical setup.
