Author Topic: right cylinder works only in  higher revs....  (Read 1243 times)
roland
« on: May 06, 2007, 08:44:43 PM »
hello to everyone.....
my right cylinder does not work when idling (1400 rpm) but will
start to work when i rev it to around 2000 plus rpm..... why?
has anyone encounter this sort of problem?
thanks,
roland
Re: right cylinder works only in  higher revs
« Reply #1 on: May 06, 2007, 08:47:22 PM »
Idle jet or passage has some crap in it?  Maybe idle mixture screw is screwed all the way in?
roland
Re: right cylinder works only in  higher revs....
« Reply #2 on: May 07, 2007, 07:38:58 PM »
justin,
i think you are right..... (i wonder why didn't i thought about it in the first place?)
will check and clean it on the weekend and see what happens.....
thanks a lot mate,
roland
thrang
« Reply #3 on: May 07, 2007, 07:53:47 PM »
sounds like a blocked jet to me
« Reply #4 on: May 07, 2007, 10:31:03 PM »
No prob, I hope it's something simple like that.  The simple problems are usually the ones that give me the most trouble as I am always looking for some exotic strange fault!  I often need to be reminded to check the simple stuff...
