Author Topic: carb popping  (Read 1013 times)
manxr65
carb popping
« on: August 31, 2010, 03:44:07 PM »
can anyone tell why this is happening.
i been out all day and stopping at different places , turning the fuel off at every stop . as my r65 is a cafe racer i only use a toggle switch as an on/off instead of a key. the thing is when i return to the bike after all different times i flick the toggle switch to power up and one or the other carbs will blow a puff of smoke out as if its just sparked and burnt excess fuel , how would this happen and why and how do i stop it
Re: carb popping
« Reply #1 on: August 31, 2010, 04:41:41 PM »
Don't know what year bike you have, but with the electronic ignition bikes, when you turn the key, or in your case a switch to the on position, the ignition system fires both spark plugs .
One of the little quirks of the bike .
If you have fuel in a cylinder an open intake valve, the fuel gets ignited and you get a small pop or wheezing/whistle sound from the engine .
manxr65
Re: carb popping
« Reply #2 on: August 31, 2010, 05:12:15 PM »
yes thats right , that blowing sound , an i have a boyer fitted . mines a 79, so it normal then. just a bmw thing
Re: carb popping
« Reply #3 on: August 31, 2010, 07:36:28 PM »
...so it normal then. just a bmw thing
Yep. I will occasionally toggle the right-side cut-off switch just to enjoy the little "poof" from the EPCO muffs. If it doesn't ignite a small flash, I'm disappointed.
BTW, On my 1981 R65, I have a simple toggle switch instead of the keyed ignition.
Monte [smiley=bath.gif] Hey, look... bubbles. Poof!
