Author Topic: Fuse Box Location '86 R65  (Read 2289 times)
Offline Matt Chapter
  • <insert witty remark here>
« on: August 13, 2010, 09:10:02 PM »
My clymer manual suggests that the fuses can be found under the seat and tool tray, however my particular R65 doesn't have a tool tray.  (The tools are stored in the body work that houses the tail light.)  The only thing I've seen that could be fuses are two white pill shaped ceramic pieces with a metal band each across them lengthwise in a little plastic box just above the battery where the frame backbone ends.  Are these the fuses, and if not where else should I look?
Thanks,
Matt
'04 R1150 RT ~41000 miles
Re: Fuse Box Location '86 R65
« Reply #1 on: August 13, 2010, 09:46:03 PM »
Those are the fuses, two 8 amp and cheap looking .
« Reply #2 on: August 13, 2010, 10:46:24 PM »
It is a fuse-type that was very common in Europe for a long time.
Probably for as long as the U.S. has had the mini glass fuses.
« Reply #3 on: August 14, 2010, 08:04:07 AM »
Matt,
The little wiki here at R65 dot org has an article prepared by some goofball that works pretty well. Eliminates the troublesome Euro-style fuses in exchange for a weatherproof mini-blade set up. NAPA has what you need.
http://www.suraklyn.com/r65_wiki/wikka.php?wakka=BladeFuse
« Reply #4 on: August 14, 2010, 12:10:39 PM »
Thanks guys... next time you're in Austin (Texas of course!) Let me know.. I know where the locals keep the cold beverages.
« Reply #5 on: August 14, 2010, 12:51:00 PM »
There are aftermarket alternatives to the stock fuse box .
Here's just a small sample of what's available .
http://www.easternbeaver.com/Main/Products/Fuseboxes/fuseboxes.html
http://www.centechwire.com/catalog/cycles/ap1.shtml
« Last Edit: August 14, 2010, 12:55:17 PM by Bob_Roller »
« Reply #6 on: August 14, 2010, 03:03:12 PM »
Thanks for the invite, Matt. Just might take you up on it as I'm down there quite often. Both my sons and grandkids live in that last bastion of the Texas Democratic Party.
Bought both my R65s in Austin. Hey, Bengt... there's free coffee and pastries every Saturday morning at Lone Star BMW.
And, Matt... I could probably lead you astray at some of the Austin joints I frequent!
« Reply #7 on: August 14, 2010, 07:16:48 PM »
Those European fuses are why in some climates cleaning and re-greasing the fuses is an annual Volvo 240 ritual - if you don't like walking...
« Reply #8 on: August 15, 2010, 06:05:18 PM »
I think I'm going to try Monte's solution, since the expenditure is probably the least.  Sure enough, when I opened it up, the fuse was broken.  Long story short, it was my fault when I was replacing the wiring harness I had taken them out and bent one putting them back in.  With any luck, I'll be able to implement the fix tomorrow.  I'd never had any fuse trouble until now, so I can't complain.
I find Lone Star to be a typical BMW dealer, although they do have triumphs to look at, and they also did turn me onto a local mechanic that's willing to work on the R65 for jobs I don't want to do.
« Reply #9 on: August 15, 2010, 08:58:28 PM »
... they also did turn me onto a local mechanic that's willing to work on the R65 for jobs I don't want to do.
Wud ya PM me the mechanic's name and contact info? Thanks.
