Author Topic: Trail-Tech Vapor Revisited  (Read 1525 times)
« on: July 29, 2010, 02:33:43 PM »
I received my Vapor today, nice compact little unit.  This is like the one Monte used on his except I opted for black instead of silver.  I will probably install it next week when I have time to think everything out.  I have also bought an R1150RT instrument cluster off flea-bay of which I will incorporate the rider information display portion into a Vapor mounting bracket/dashboard panel.  The RID should have every idiot light I need and then some.
Probably the only light that will never be used is the "Low Fuel" telltale...
« Last Edit: July 29, 2010, 06:53:00 PM by admin »
Re: Trail-Tech Vapor Revisited
« Reply #1 on: August 04, 2010, 06:35:54 PM »
I made some basic mounting brackets and finished mounting up the R1150RT RID and Vapor today.  I need to make some sort of "housing" to go over the back of the RID as without the fairing this arrangement is really butt-ugly!  And, even with the fairing it's a bit homely due to the "stack" height.  BUT, I really like the way the RID displays everything so I guess I'll live with it.
The tach and speedo function flawlessly and checking the speedometer and odometer against mile-markers on the Interstate show it is dead-on!
This is what I wound up with...
« Reply #2 on: August 04, 2010, 08:39:35 PM »
Have you found black socket-head fasteners that don't rust?
« Reply #3 on: August 04, 2010, 09:46:17 PM »
Unfortunately, no.  I'll probably replace these with stainless in the future but I don't have any in that size at present...  Looking at the handlebar clamp bolts I think I need to get stainless for them as well!  :o
« Reply #4 on: August 04, 2010, 10:41:56 PM »
What about powder-coating just the heads?
That would be small enough, it could be done at home.
Can that be safely done in a kitchen stove, or do you have to dedicate a stove to it?
I bought a stainless "kit" for the engine side covers on my CB200 from a guy on eBay.
They didn't match very well, and came with a lot of hardware I don't need.
I contacted him, and he sent me a special order that was supposed to fix my omissions.  I got all I needed plus a couple, except still no M6x55. :(
Luckily there are a couple of long ones in the original kit and I should be able to cut one down.
Of course, they are silver, which is fine, as long as I keep the engine stock, but I hope to paint it black, someday.
Here is a good source for small quantities:
http://www.boltdepot.com/dimension.aspx?cc=25&cs=81&cm=19
azcycle
« Reply #5 on: August 05, 2010, 12:06:34 AM »
Looks pretty good! I assume that fuel indicator light is inoperative?  I'm about to pull the trigger on a Vapor myself. I'd prefer an Acewell but it seems their American distributor went belly-up.  I think I'm going to go with their LED "dashboard" and just use a Radio Shack mini-bulb for the charging system.
Still don't know how I want to solve the ignition issue. I like your solution... would you mind explaining how you set up your ignition mount?
« Reply #6 on: August 05, 2010, 03:11:50 AM »
Yes Justin, a picture from the rear! :)
« Reply #7 on: August 05, 2010, 07:22:24 AM »
Ah, Texas in the summertime...
Note the temperature readout, top-left, on the Vapor...  111 degrees! That's probably while in the shade of Justin's shop.
We be sweatin' with the oldies... oldie BMWs, that is.  Monte :-X
« Reply #8 on: August 05, 2010, 03:54:56 PM »
Yeah, summer came back with an attitude...  :P
Rob, on an old Honda CB450 I had years ago (my first street bike) I painted the cases wrinkle black and then polished all of the covers and added polished hardware - the contrast really looked bitchin'!
Monte, have you hooked up your EGT sensor yet?  I need to either cut-and-splice or get an extension cable...
« Reply #9 on: August 05, 2010, 03:57:25 PM »
I'll take a couple pics if I have occasion to have the fairing off.  I basically made two little angled tabs that are bolted to the top of the bar clamps and then the other stuff attaches to the little tabs.
« Reply #10 on: August 05, 2010, 04:18:18 PM »
...Monte, have you hooked up your EGT sensor yet?  I need to either cut-and-splice or get an extension cable...
Negative. Way too exotic for me. I have enough trouble as it is just switching the Vapor from standard to daylight savings time. ;D
