Author Topic: Final Drive Sight Plug Repair  (Read 1779 times)
« on: July 20, 2010, 01:34:12 PM »
Oh, the joys of riding an old motorcycle that had lived under a tree for 15 years and was partly disassembled.  When I started riding the Dawg I knew that the sight plug hole had been stripped and what looked to be a 1/8" NPT brass plug had been installed.  It looked/felt secure so I didn't screw around with it.  Yesterday I happened to look down at the final when I had the R/H saddlebag off and noticed "no plug"!!   I guess I can blame it on Bob.  ;)
The hole was already huge and I didn't have a plug big enough so I drilled the hole a bit larger, tapped it M12x1.5, and decided to make some sort of insert.
I coated the drill bit and tap with sticky grease to catch the chips and then prepared the hole:
I then turned down and tapped a short piece of aluminum to M12x1.5:
Then drilled it through with a 5mm hole and tapped it to M6x1.0:
I then parted off the threaded piece I was going to use for the repair.  I inserted a 6mm bolt with lock-nut, coated the insert threads with JB-Weld, and then screwed it into the freshly tapped and cleaned hole.  I flushed both the insert and tapped hole with lacquer thinner before gluing it in.
The insert was first screwed in with low torque:
Then the bolt and jamb nut were removed after the JB-Weld had set up:
I then made a new plug from a 6mm stainless steel bolt and fitted a copper washer:
The new plug was then installed into the repaired hole:
« Last Edit: July 21, 2010, 09:28:12 PM by admin »
Re: Final Drive Sight Plug Repair
« Reply #1 on: July 21, 2010, 10:33:05 AM »
Hi Justin,
That sounds like a different 'twist' on the the ol' Time-sert/Helicoil approach - unfortunately it seems like there are supposed to be pics with the descriptions, but the pics aren't there?
« Reply #2 on: July 21, 2010, 11:55:10 AM »
Crap...  I don't understand why they are not showing!
« Reply #3 on: July 21, 2010, 04:31:28 PM »
Oh!  There are supposed to be pictures?
No wonder I couldn't understand anything.
mimmo66
« Reply #4 on: July 21, 2010, 09:15:53 PM »
I love it!
It reminds me of friend of mine who could make anything with metal !
Great Job! :)
« Reply #5 on: July 21, 2010, 09:25:41 PM »
CRAP!!!!!!!!
« Last Edit: July 21, 2010, 09:30:01 PM by admin »
« Reply #6 on: July 21, 2010, 11:14:28 PM »
I am very envious of those folks - like Justin- who have the experience and the tools (lathe, drill press, MIG/stick welders, etc.) to do such fabrications, and then paint them all up so purty afterwards!
« Reply #7 on: July 22, 2010, 02:03:55 AM »
I wish I could do that with my stripped driveshaft drain plug.There is not enough depth to helicoil it,I'd have to remove the threaded ring to do that,which may mean a new oil seal...seems a lot of work.I've been gluing it in the the last couple of changed - now I'll do a JB job,and pull back the final drive to drain.Until I get sick of that and do the job properly.
« Reply #8 on: July 23, 2010, 08:57:04 PM »
Genius! I love it! Looks the proper repair!
« Reply #9 on: July 24, 2010, 07:18:27 PM »
So far, so good...  After gluing it in I remember thinking, "Dumbass, why didn't you make it out of stainless?"...
« Reply #10 on: July 24, 2010, 10:39:00 PM »
Justin, do you have a lathe and a mill?  I have tool envy.
« Reply #11 on: July 25, 2010, 04:47:26 AM »
Ed, yes, small ones...
