Author Topic: Front Disk Replacement-Alternatives  (Read 2272 times)
mimmo66
« on: July 18, 2010, 05:15:52 PM »
Was just wondering if there's a 'Cheaper' solution to replacing front disks.
With Double front disk, EBC route will offset me by +/- $500
Coulld be more expensive if original parts were ordered.
I would like to just pop the old disks out of carrier and put new ones in.
Any suggestion or advice?
Re: Front Disk Replacement-Alternatives
« Reply #1 on: July 18, 2010, 06:32:43 PM »
Gonna be a tuff nut.
Double EBCs will be very nice and less bucks than OEMs. Only other option would require a patient, and perhaps quite lengthy, search for near-new OEM discs from a breaker.
My understanding is the OEM discs cannot be turned.  :'(
« Reply #2 on: July 18, 2010, 06:58:13 PM »
Folgore, how many miles on the bike?   How frequent do most people change the pads?  I've only had to change one disk, a rear on Mrs. Phorqs R1100R at about 50K, and that because the PO had neglected to change pads on a timely basis.
« Reply #3 on: July 18, 2010, 08:52:02 PM »
Speigler will put semi-floating stainless discs on the original carrier, or hub, but not a better deal cost wise, they are about $240 for each rotor .
http://spieglerusa.com/BMWConversions/
« Last Edit: July 18, 2010, 08:53:08 PM by Bob_Roller »
mimmo66
« Reply #4 on: July 19, 2010, 12:10:48 AM »
we're nearing the 50k mark, and I was just planning ahead in my service schedule.
If my memory serves me well, the  front pads were replaced about 15k miles ago.
I understand that until you start noticing tiny cracks on the drilled wholes, the disks are still ok.
« Reply #5 on: July 19, 2010, 11:02:09 AM »
The rotors are considered worn out, when they get to .180 inches thick .
I have an LS, that the previous owner had the rotors machined to remove the heavy grooving, the thickness at the edges where the pads don't contact, were .140 inches thick .
I found between both rotors, 13 cracks that ran between the holes in the rotor .
With the grooves that were present on the rotors, there were areas where the rotor was no more than .040 inches thick .
I would check the thickness of the rotors to determine whether they are worn or not, factor in the groove depth as well .
nothing
« Reply #6 on: July 19, 2010, 03:58:16 PM »
http://www.wemoto.com/pictures.dyn?u=5834606qqq5828634
Cheap compared to any other alternative I found.
If anybody tries these, please post your experiences.
Personally, I went with a good used OEM rotor when one of mine warped.
« Reply #7 on: July 20, 2010, 02:35:05 AM »
Cheap brake parts.
Why does this sound like false economy?
I ran my discs grooved for a long time.  Then Bob Roller mentioned someone having the EBC rotors on sale [about 3 years ago] (who was that, Bob?).  I snatched one up.  I noticed NO improvement in braking.  And I had no complaints before I replaced it.
This is what my old one looked like.  The picture really doesn't do the grooves justice.  They were deep!  But I don't have a micrometer, so I couldn't measure them.
« Last Edit: July 20, 2010, 02:40:23 AM by Rob_Valdez_79_R65 »
« Reply #8 on: July 20, 2010, 09:42:28 AM »
Rob that was me that got the EBC rotors the same time you did from Bike Bandit .
I too haven't noticed any improvement in dry braking, but wet braking is greatly improved .
Also the EBC FA18 graphite pads don't produce brake dust that makes the wheel look pretty grungy, and is a pain to get off on the snowflake wheels .
