Author Topic: Ignition coils  (Read 1142 times)
Dizerens5
Ignition coils
« on: July 14, 2010, 01:17:22 PM »
Hello folks, I am wondering if anybody recognises the ignition coil on the photo attached....it's one of the 6v pair off my 1979 R65. I had a mysterious misfire but it seems to have been fixed by replacing the coils with Bosch ones. The pattern pair are painted black end to end and have no indication of manufacturer, country of origin or anything else except "09-205 6 volt standard". They do seem to have caused the misfire but a test meter shows resistance of primary and secondary on both must be about right (I don't have correct figures but they are surely "in the ballpark"). Anyone know where these coils come from and if they are any good?
Re: Ignition coils
« Reply #1 on: July 14, 2010, 02:28:13 PM »
I seem to remember this coil coming up on the forum once before so maybe a search would find a thread. Here is a what I think is the UK distributor which lists the bosch equivalents.
http://www.currentcare.co.uk/index.php?showprod=7320715
Re: Ignition coils
« Reply #2 on: July 14, 2010, 02:29:54 PM »
Probably make niffty fishing weights!
Have heard of phony, cheap-o, counterfeit coils being sold to the unsuspecting. My '83 R65 arrived with two 6V coils attached to the backbone with a single huge hose clamp. Dyna brown done come to town... do dah
Dizerens5
Re: Ignition coils
« Reply #3 on: July 14, 2010, 03:35:40 PM »
Thanks Barry. Based on your weblink an internet search suggests these coils may possibly be made by Lighten Point, a small aftermarket electrics company I've never heard of,  in Leeds (UK), set up in 1977 and now part of Ring PLC, which is pretty well known here, if a bit downmarket I suspect.
Lighten Point claims to make high quality products. If so, why don't they put their name on them?
Re: Ignition coils
« Reply #4 on: July 14, 2010, 03:53:48 PM »
You might also want to consider replacing your wires and caps.
If you still have the original BMW caps with the metal shroud, I would definitely replace them with some nice, water resistant NGK caps.
Also, if you have the original wires/caps, remove the wire tip that goes into the coil.  It will be soldered on, so you need to heat up the solder to remove them.  They are far superior to the clamp on type.
soc7260
Re: Ignition coils
« Reply #5 on: July 16, 2010, 08:58:14 AM »
"Also, if you have the original wires/caps, remove the wire tip that goes into the coil.  It will be soldered on, so you need to heat up the solder to remove them.  They are far superior to the clamp on type. "
Or you can give them a good hard tug and similtaneously remove all that pesky skin from your knuckles like I did.
Re: Ignition coils
« Reply #6 on: July 16, 2010, 10:30:33 AM »
...Or you can give them a good hard tug and similtaneously remove all that pesky skin from your knuckles like I did.
It's really not a worthy project unless there's a wee bit o' blood to show. :D
Re: Ignition coils
« Reply #7 on: July 16, 2010, 07:45:40 PM »
Or you can give them a good hard tug....
That's the stuff that previously owned bikes are made of!
