Author Topic: How much fork oil?  (Read 8316 times)
VaSteve
How much fork oil?
« on: April 22, 2007, 09:23:41 PM »
So I finally got around to changing the fork oil in the bike.  What a messy job.  I should have had a smaller funnel, cause I had fork oil all over the place.
Anyhow, I had the bike on the center stand with the front fork fully extended as I was told.  I filled the forks up with 15W fork oil from the dealer and it seems stiff.  A lot stiffer than before.  Almost too stiff.
I read in Clymer how much I was supposed to put in (fat chance measuring that).  It was all the way up to the threads on the cap.   In fact, I dabbed some out with a paper towel when I put the caps on.  Did I put in too much?  If so, how much should I take out?
thanks
Steve
Online Bob_Roller
Re: How much fork oil?
« Reply #1 on: April 22, 2007, 09:49:14 PM »
My BMW shop manual shows 190 cc for just an oil change on the forks. I'll go out to the bike and and see what the owners manual has to say about it. Owners manual states 190 cc as well. If you have that much oil in your forks, don't ride it until you have reduced the level, or you will probably have a severe leak before you know it! My only suggestion is to drain it and start over, or you may be performing a fork seal change shortly.
« Last Edit: April 22, 2007, 09:56:23 PM by Bob_Roller »
« Reply #2 on: April 22, 2007, 09:58:57 PM »
Oooh yeah.... you've got waaaaaay too much oil in there !
Remember from high school that liquid is incompressible (well, mostly, anyhow) ?
You gotta have some air space in those sliders for the spring to compress and the
fork sliders to move !   There are many schools of thought on how much oil and of
what weight it the best amount for different types of riding, but the basic specification
for those fork tubes is about 200cc per fork tube.   Get a smaller tipped funnel - you can
get one with long flexible hose ends at most automotive stores, and a cheap clear plastic
measuring cup with metric (cc) markings from a hardware or kitchen supply store.   Fully drain out both your fork tubes and start over again !
If the forks have been totally disassembled, the spec indicate maybe a little
over 200 cc of oil is needed, versus a little under 200cc for a simple oil change procedure.   In any case, by my estimates you have about 5X the amount of oil that should be in there.
Did you drain the original oil and check how much came out ?
« Reply #3 on: April 22, 2007, 09:59:55 PM »
I, like Bob, went out and checked my owner's manual.  190 cc is right.
It's easy to measure if you buy a syringe at a feed store; mine measures up to 60 cc.  I don't want to know what the real purpose is for these syringes.
VaSteve
« Reply #4 on: April 22, 2007, 10:02:34 PM »
Ah, OK, thanks.   I have plenty of syringes (makes giving a baby medicine easier).
190cc...is that per side?
« Reply #5 on: April 22, 2007, 10:07:10 PM »
The others are correct, if you filled it all the way to the top then it is WAAAAY too full and I'm surprised you haven't blown out your fork seals yet!!  Time to start over.  I went to the local TSC store (that's Tractor Supply for you yankee city-boys  ;)) and got a 60 cc syringe (no needle) and it works great for filling forks, fits into the itty-bitty filler hole with no problems and lets you measure it exactly without spilling a drop.
Now, once you get the correct amount in I would imagine that the 15w will still be a bit stiff.  I have 7.5 w and think that being a "full sized" person 10w might have been better.  You could get some 7.5w and mix with the 15w if you were wanting something a bit stiffer than the 7.5w...  I actually found that the BMW fork oil was cheaper (at least around here) than the stuff carried by the jap shop - that was a shocker!!!  Or, they were having a hard time getting rid of the 7.5w, I bought a couple jugs of it...
Online Bob_Roller
« Reply #6 on: April 22, 2007, 10:23:15 PM »
Yes, thats 190 cc per fork.
« Reply #7 on: April 23, 2007, 09:18:15 PM »
And watch the torque on those drain bolts.  Not too much!!!
VaSteve
« Reply #8 on: April 25, 2007, 06:43:48 AM »
Thanks guys, I'm hoping to get to it this week.  Meanwhile, the bike is parked.  Hopefully, you won't have to walk me through a seal replacement...but I'm sure that's within my capabilities (or not) as well.
Online Bob_Roller
« Reply #9 on: April 25, 2007, 12:08:40 PM »
Could I make a suggestion here? How about make a posting about the job you are going to do, and especially if you've never done the job before, or your not too sure of your mechanical abilities, and get the info you need and helpful tips that are not included in the manuals, before you start the job,and not waste time and effort and possibly cause unnecessary damage to your bike. Possibly it could be it's own section of this forum, or a subsection of one of the existing technical categories.
« Last Edit: April 25, 2007, 01:22:23 PM by Bob_Roller »
VaSteve
« Reply #10 on: April 25, 2007, 02:58:31 PM »
Wow, I don't know if that was a general suggestion or directed at me specifically.
Frankly, I didn't think it was that big of a job and i don't always have time to clear my jobs through the collective.  But I'm pretty sure of my mechanical ability in most cases.
FWIW, I did suggest something like a sticky section of common issues...not using the gasket that comes with the oil filter for instance.   But i never got implemented.
I'm going to take the rear shocks off next and replace the springs...are there any tricks to that?   Can I actually separate the spring from the shock?  I see them for sale assembled.
« Last Edit: April 25, 2007, 03:10:13 PM by VaSteve »
Online Bob_Roller
« Reply #11 on: April 25, 2007, 03:25:29 PM »
No Steve, not aimed at you it, just has brought back quite a few instances over the years when somebody has gotten themself into really serious situations that could have easily been prevented if they knew of a few little tips and hints ahead of time , instead of after the fact. Lets face it, the info available from what you would consider reliable sources, turns out to be incorrect sometimes. In my BMW shop manual, it shows 190 cc as the correct amout of oil per fork, but it also states .4 quart for the US measure. Well .4 quart is 380 cc, so even the factory manual is wrong here. What I'm trying to say here is, it might be a good idea to get some input from people that have done the job before, and steer an owner clear of possible trouble spots.
« Last Edit: April 25, 2007, 03:28:53 PM by Bob_Roller »
VaSteve
« Reply #12 on: April 25, 2007, 03:28:57 PM »
No Steve, not aimed at you it, just has brought back quite a few instances over the years when somebody has gotten themself into really serious situations that could have easily been prevented if they knew of a few little tips and hints ahead of time , instead of after the fact. Lets face it, the info available from what you would consider reliable sources, turns out to be incorrect sometimes. In my BMW shop manual, it shows 190 cc as the correct amout of oil per fork, but it also states .4 quart for the US measure. Well .4 quart is 380 cc, so even the factory manual is wrong here. What I'm trying to say here is, it might be a good idea to get some input from people that have done the job before, and steer you clear of possible trouble spots.
OK, no offense taken then....  Seems that R65's get short shrift in the manuals anyhow.  This hopefully isn't a catastrophe...it's no $2000 o-ring!!
« Reply #13 on: April 25, 2007, 09:22:18 PM »
VASteve -
Not sure what you have for rear shock absorbers, but many of them require some special
tools to compress the spring for (dis)assembly.  Since it is a big spring, it takes alot of
pressure, and can be a bit dangerous to do without proper equipment.   A number of
companies offer regular or heavy duty springs for the same shock absorber, and dealers
carrying them have the equipment to install/repair the shocks.   An example of this are
the Progressive (brand) shocks, which have regular and heavy duty springs for sale.
If you buy the shocks from Bob's BMW, for example, they will assemble them for you.
hope this info is helpful,
Mike
« Reply #14 on: April 25, 2007, 09:56:14 PM »
You will most likely need a spring compressor, as already pointed out.  It is basically a couple of chunks of all-thread with a hook and nut on each end.  I think Harbor Freight has them pretty cheap.  I have never looked at the factory shocks but Konis have like a big slotted retainer/washer on top that it looks like will slip right off once you relieve the springs.
