Author Topic: Missing - one needle bearing  (Read 1088 times)
Red_Hen
« on: May 17, 2010, 06:59:01 AM »
Hi Gang,
Spent 1/2 an afternoon yesterday on R65LS.  Had a gut level that a needle bearing or two might be missing - we pulled rocker arms and sure enough on the last one, one needle bearing is missing.
Do I need to go and buy a complete assembly or is it feasable to get a hold of one bearing and put it where it belongs?
Bought a new ignition switch - are there any posted pics of which wires go where?  We have a Clymer's service book but the schematic is pretty vague.
I plan to bring bike home this week and will post pictures of more questions as to what goes where - all electrical questions.
Getting closer but then . . . sometimes I feel like dropping it off at a shop and saying call me when it's done!
Re: Missing - one needle bearing
« Reply #1 on: May 17, 2010, 12:14:27 PM »
There is normally a small gap  when all of the needles are pushed together .
If you can extract one needle from the other bearing and see if you can get it to fit, most likely you can't .
You're not the first to have doubts about this .
« Reply #2 on: May 17, 2010, 12:43:36 PM »
I don't know if the '79-'80 models had needle bearings, but if they do, I will have a spare if you need it.
Red_Hen
« Reply #3 on: May 17, 2010, 12:58:34 PM »
There is no doubt that I'm missine one needle bearing.  We checked all four and the last one came up one short.
« Reply #4 on: May 17, 2010, 01:28:30 PM »
Then I guess you need to get a replacement needle .
Unless you get just the needle from someone that has some, you're only other course is to purchase a bearing .
« Reply #5 on: May 17, 2010, 01:47:20 PM »
I have a wrecked engine with all sorts of miscellaneous parts.  NBD.
Crossrodes
« Reply #6 on: May 17, 2010, 02:25:34 PM »
Rob, my '79 has needle bearings in the rockers so most likely the one you have will too.
« Reply #7 on: May 17, 2010, 03:40:35 PM »
They have already been dropped in the mailbox to Ken! :)
