Yes installed correctly as they have a arrow marked on the body. Its the strangest thing, new filter, tank with clean gas, petcock removed (twice) opened up and looking good, fuel streams down good from the tank without filter and then stops when the filter is installed. Removed, blow air through, fuel comes out and back on line. After doing this a couple of times I can get it to work with the tank on the workbench. Now lets see if it works with the tank on the frame.
