Author Topic: oil filter cover and helicoils  (Read 760 times)
Darwin_R65
« on: March 28, 2010, 06:36:22 AM »
I have a stripped thread on my oil filter cover.
It was like that when I bought it, but the other two bolts seemed to clamp the cover enough so i never worried about it, until today.
Decided to try some permatex stripped thread repair. It's basically a 2 part epoxy.  Failed miserably and now it appears the other two aren't sufficient to keep it from leaking, may be the new gasket provides enough movement to not seal correctly.
So next step is helicoil. Trouble is I cannot get a clear view of the hole past the frame so obviously drilling and tapping for helicoil will be a problem. (It's the upper most forward bolt)
So my question is has anyone else had to do this hole before?
Can I remove the forward engine mount and just drop the engine slightly?
Does anyone have a magic wand I can wave and pixies will appear and just fix it for me?
Lately too much working on the bike and not enough riding.
John
Re: oil filter cover and helicoils
« Reply #1 on: March 28, 2010, 08:30:11 AM »
John,
I feel your pain and frustration. Frequently, I have to forcefully remind myself that I do enjoy messing with these older motorcycles. A frosty adult beverage will ease the pain... for a little while [smiley=beer.gif]
I'm going to offer a WFO ghetto fix that I have not attempted on an engine crankcase -and would also not encourage you to try- until a few other R65 dot orgers have flamed in. Here tis:
It might be possible to replace the Metric 6x20 oil filter cover bolt with an SAE 0.250 bolt of a similar length. (6mm=0.2367 inch) My off-center thinking is that a 0.250 grade-8 hardened bolt could be modified to act as a self-tapping bolt. By filing three or four small "notches" equidistant around the business end of the threads, a DIY tap might cut the aluminum block if pressure was applied to the bolt during the turning operation.
Back out the bolt frequently to clear the swarf and finally fit a non-modified 0.250 bolt to finish off the job. I have not tried this technique in an engine case but the procedure has been successfully done on a stripped cylinder head center stud for the rocker cover.
Your mileage may vary, amigo. I do hope a few peeps smarter than me will post up with better ideas. Of course, moving the engine may be a wise man's best course of action. In the meantime, go watch the SBK race from Portugal...
Darwin_R65
« Reply #2 on: March 29, 2010, 05:31:28 AM »
pulled out my imperial taps today and ran a 1/4 inch tap down the thread.
It hurt to mix imperial with metric, but it's done.
John
« Reply #3 on: March 29, 2010, 02:50:46 PM »
Just try and remember to pass that along to the next owner (if there is one in your lifetime!).  They will appreciate it.
Darwin_R65
« Reply #4 on: March 29, 2010, 08:27:30 PM »
And deprive them the JOY of discovering their new bikes perculiar personalities :) :D
