Author Topic: aux plug  (Read 1011 times)
Offline steven m
aux plug
« on: March 27, 2010, 02:58:11 PM »
Hooking up the factory aux plug that came with my 83 R65 and wondering how to tell which lead is positive and which is negative.  Both leads are black as they come out of the sheath.  Does it matter?
Steve
Re: aux plug
« Reply #1 on: March 27, 2010, 03:12:50 PM »
It does matter .
The wire that goes to the center contact of the plug is the positive one .
If you have a multi meter, put an ohm meter lead on the center contact, and then the other lead at the other end of the wire harness, and see which wire gives you continuity, place that wire on the positive terminal of the battery .
bruce_launceston
Re: aux plug
« Reply #2 on: March 27, 2010, 06:34:27 PM »
If it is a 'factory' setup the positive wire should have an in-line fuse holder in it.
Offline steven m
Re: aux plug
« Reply #3 on: March 27, 2010, 08:44:49 PM »
THANKS!  Sliding the outer sheath reveals a red wire with an inline fuse, which I think should be the hot positive as well as a brown wire, which is the standard BMW ground color.  Just hooked it up.  Will check with a multimeter.
Steve
Aristotle
Re: aux plug
« Reply #4 on: March 28, 2010, 04:31:00 PM »
why does BMW use a brown colored sheath conductor for a ground??
It is normal practice for grounds to be green or green with yellow stripes??
I know this for a fact as I'm an electrician by trade.
but I do wonder why BMW designs ground to be brown rather than the standard colors normally used.
Re: aux plug
« Reply #5 on: March 28, 2010, 04:39:54 PM »
It's pretty much a European -or is it just German?- automotive/motorcycle standard. My Mk1 VW Cabriolet and my 60's era Porsche are/were full of 'em. Both the R65s are brown=earth.
I remember it as Brown-Earth-Ground-Dirt :D
« Last Edit: March 28, 2010, 04:41:22 PM by montmil »
