Author Topic: Best penetrating oil?  (Read 616 times)
« on: March 27, 2010, 06:44:02 AM »
This is forwarded from the ABC list where it was posted from another list, etc, etc...   Monte
<quote>
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a scientifically rusted environment.
Type of penetrating oil ..... Average load
None ................................ 516 pounds
WD-40 ............................ 238 pounds
PB Blaster .......................214 pounds
Liquid Wrench .............. 127 pounds
Kano Kroil .................... 106 pounds
ATF-Acetone mix......... 53 pounds
The ATF/Acetone mix was a home-brew mix of 50/50 automatic transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that Liquid Wrench is about as good as Kroil for about 20% of the price.
</quote>
darrylri
Re: Best penetrating oil?
« Reply #1 on: March 27, 2010, 07:29:41 AM »
When my can of Kroil runs out, I'm going to try the ATF-Acetone mix!
