Author Topic: headlight fault  (Read 1364 times)
chris_blake
headlight fault
« on: March 18, 2010, 02:54:25 AM »
86 r65 mono i have lost dipped beam on my headlight high beam is fine as are all other electrics the bulb is ok.have checked continuity from switch to bulb and bulb to what i think is the connecting on top of frame behind headstock. could the problem be with the switch itself how would i check this as you cannot remove wires from the switch end.could it be the headlight relay in whtch case which relay is it and how do i check it please keep it simple guys my brain hurts when it comes to electrickery as always many thanks in advance
Re: headlight fault
« Reply #1 on: March 18, 2010, 07:58:31 AM »
The momentary, or spring loaded position of the switch, uses a contact in the switch that is not used in the other two positions, I would guess that something in there is broken .
I wouldn't suggest trying to take it apart, they are not 'user friendly', and no parts are available, cost around $100US .
The headlight relay is only used during starting, to shut off the headlight during starter operation .
« Last Edit: March 18, 2010, 08:25:51 AM by Bob_Roller »
Re: headlight fault
« Reply #2 on: March 18, 2010, 09:24:17 AM »
When the dipper went south on my 81', I gave up on rehabing the interior bits -that little bitty ball bearing can be a PITA- and caller RePsycle BMW Parts. Got a later model with much fresher components for less than half the dealer price. Did require a short job of matching the proper wire terminals but that was cake.
http://re-psycle.com/ Ask for either Mark or Marco. They know their stuff.
chris_blake
Re: headlight fault
« Reply #3 on: March 18, 2010, 01:36:17 PM »
thanks guys will try to find secondhand switch cheers chris
Re: headlight fault
« Reply #4 on: March 18, 2010, 02:26:47 PM »
I think that someone is also parting out handlebar switch assemblies from an R65 on ebay at this very moment.
http://cgi.ebay.com/ebaymotors/BMW-1983-R65-Left-Handlebar-Control-Switch-with-Lever_W0QQitemZ330413689127QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item4cee30c927
Oops - just noticed that your signature says "Essex" and I guess that you mean an Essex that is somewhere other than in the United States..so perhaps that ebay switch isn't a viable option for you..
« Last Edit: March 18, 2010, 02:42:57 PM by nhmaf »
Darwin_R65
Re: headlight fault
« Reply #6 on: March 19, 2010, 05:09:29 AM »
If you lift the petrol tank, and pull apart the connectors, it's simple to put a multimeter on OHMS and test the switch, but you'll have to read the circuit to work out which wires. I don't have a circuit for a 86 model.
