Yep should be smooth. Mine always is when I pull it off. I usually check every gear by hand.
How many miles on this box?
Is the box making noise? Normal gearboxes whine a bit in 4th gear but make no other noises. Hollow "thunks" while shifting usually mean something needs to be shimed.
Is the magnetic plug covered with shinney chunks or is it just dirty fuzz? (Dirty fuzz is normal)
Does the oil coming out of the tranny look like fresh gear oil or does it look like chocolate milk? (Water contamination through speedo cable)
What does the tranny input spline look like? When you re-install this make sure you only put grease (Honda Moly) on the tranmission part of this equation plus a little dolip on the tip of the end of the clutch actuating rod (in the center if the tranny input spline). DO NOT put
any grease on the inside of the friction plate (the female part of this equation). If you do the tranny input spline will push this grease to the center of the clutch where through centriugal forces it will be slung onto the forward half of your clutch friction plate. This contamination will render half your clutch
useless. The other half will end up being burned and scored and will cost you big bucks to replace.
The picture in the Clymer manual showes white grease on the female portion. (Resist the urge to do the same!) You may clean the female part of the friction plate but do not grease! (With a tooth brush and only with outward strokes. Do not push dirt and cleaner into the clutch.)
Ask me how I know these things....
