Author Topic: R65 Tank length.  (Read 1187 times)
R65 Tank length.
« on: February 16, 2010, 09:20:00 AM »
Could sombody put a tape measure on an early R65 tank for me - I'm on the road.
I need the distance from the front lip of the tank down through the tunnel to the back lip of the tank.
Thanks in advance,
Bill
Re: R65 Tank length.
« Reply #1 on: February 16, 2010, 11:27:08 AM »
Bill
I make it 21.5" from front lip to rear lip. Someone else should measure as well to check.
« Last Edit: February 16, 2010, 11:32:59 AM by bhodgson »
DgM
« Reply #2 on: February 16, 2010, 12:46:43 PM »
My 1983 tank measures 23" in a straight line from front to back tank lip (flange) to lip (flange) - 23.5" with tape measure following curvature under tank along tunnel.
« Reply #3 on: February 16, 2010, 12:52:41 PM »
I measured a straight line and did not follow the curvature. I think 78 - 85  tanks should all be the same size even though the seat changed in 81.
« Last Edit: February 16, 2010, 12:57:48 PM by bhodgson »
« Reply #4 on: February 16, 2010, 01:06:30 PM »
22 1/2" from rear seam to the furthest forward on the front mount.
21 1/2" to the rear-most portion of the front mount.
Measured through the tunnel.
« Reply #5 on: February 16, 2010, 10:06:19 PM »
Thanks guys.
Much appreciated.
Time to decide.....
