I put a gallon of phosphoric acid in the tank today, removed the 'flash' rust deposit in about 30 minutes .
Rinsed the tank out with fresh water, inserted an air nozzle into the tank, blew it out for 45 minutes, a bit of rust came back, proceeded to put the tank under a heat lamp for an hour, let it cool off, then added the POR 15 sealer .
This sealer, looked like an extremely thin silver metal flake paint .
After assuring all parts of the tank were coated, the fuel filler drain tube that runs through the tank was the only area, that was a bit difficult to get coated .
Drained the remaining liner out, and from the looks of it, you could probably coat two R65 size tanks with the motorcycle kit, that's 8 fluid ounces (237 ml) of sealing material .
Need to let it sit for 96 hours before doing anything to it .
A couple of days in the Arizona sun, should speed things up a bit !!!!!
We'll see how it turns out .
