Author Topic: Rusty Fuel Tank Interior  (Read 4500 times)
Re: Rusty Fuel Tank Interior
« Reply #15 on: November 05, 2009, 09:39:24 AM »
One of our members from the UK, mentioned, that he used treacle to remove rust from a fuel tank .
I found two bottles of dark molasses, left over from home-brewing beer, a few years ago, I'm going to give it a try, and see what happens .
Alright, at 1330 today, I put two bottles of dark molasses, and about a gallon of hot water in the fuel tank and sloshed it around a bit .
I'll continue sloshing it around until tomorrow afternoon, and then we'll see if any noticeable amount of rust has been removed .
Surface temp of the tank is 142 F. (61C.), it's still 'summer', here in the northern Sonoran desert of central Aridzona .
« Last Edit: November 05, 2009, 02:54:13 PM by Bob_Roller »
« Reply #16 on: November 05, 2009, 06:26:08 PM »
One of the guys here in the car club buys molasses from a horse supply, dilutes it 10:1 and soaks metal parts overnight in that. He swears by it...
This removes rust? What's the difference between livestock supply house molasses and grocery store molasses? I like the idea if it really works.
« Reply #17 on: November 05, 2009, 06:37:47 PM »
Apparently molasses contains an enzyme, that attacks rust .
I drained the solution out of the tank a few minutes ago, and it is quite rusty .
Looking into the filler hole, I can't really see any difference, I'll give it a few days, before I give my final opinion on it .
« Reply #18 on: November 06, 2009, 01:42:58 PM »
After 23 hours, I drained out the solution, and I got about 3/4ths cup of flaked rust .
There is bare metal showing inside the tank .
I would have to say, at this time, that this is a 'plausible' method of rust removal .
Give it a few more days .
« Reply #19 on: November 06, 2009, 06:23:26 PM »
What is the brand name of the molasses and where did you get the stuff? Have a Tractor Supply store in town if it is a specific agri biz material.   Monte
« Reply #20 on: November 06, 2009, 06:48:55 PM »
Can't tell you specifics, trash was picked up today, so the bottles are gone .
Darwin_R65
« Reply #21 on: November 06, 2009, 10:46:08 PM »
goto this Morris car club site in Australia
http://www.moreg.org.au/dissolving_rust.htm
or this iste on old Indian motorcycles that also has pictures.
http://virtualindian.org/projrust.htm#molasses
and it details the process for using Mollasses, they talk about leaving it for a week to ferment before using.
John
« Reply #22 on: November 07, 2009, 06:43:20 AM »
...and it details the process for using Mollasses, they talk about leaving it for a week to ferment before using. John
 [smiley=ROTFLMAO.gif] I knew it... I just knew it!  You guys are drinking this stuff. Homemade shine.  ;D
Monte I'll take a jug to go Miller
« Reply #23 on: November 07, 2009, 09:43:03 AM »
I've noticed, that if I leave the small stopper in the hole in the large stopper that plugs the filler hole, that there is a pressure build-up after an hour or so .
I'll definitely leave this project outside in the back yard, it has begun to develop an 'odor' .
« Reply #24 on: November 09, 2009, 01:01:47 PM »
I bet it's going to have a metallic taste.
« Reply #25 on: November 09, 2009, 01:32:48 PM »
So will you and Monte if you start drinking it.
« Reply #26 on: November 09, 2009, 01:38:04 PM »
I think that a rust taste, would be the least of your worries !!!!!!!!!
Alright, it's been 4 days since I started this 'Myth-busters Episode' !!!!
I drained the solution out of the tank, and sprayed it with a garden hose nozzle, and about 1/4th of the tank is clean down to bare metal .
Looks like areas where the liner still has a good hold, the solution won't remove the liner .
Myth 'confirmed' .
I'm going to fill the tank up , and put 8 more bottles of molasses in this afternoon .
So that's 10 - 10 ounce bottles of molasses, in a completely full tank .
Can't shake the tank now, I can only roll it onto it's side, then upside down, on an old blanket .
« Last Edit: November 09, 2009, 03:44:25 PM by Bob_Roller »
« Reply #27 on: November 22, 2009, 01:04:36 PM »
I drained the 'molasses mystery mix' from the tank,  the rust and the old liner material are gone .
Not a quick process, but it does work .
If I were to do it again, I would mix up the solution, and let it sit for a couple of weeks before filling the tank up with it .
I've got a shop vacuum cleaner with a hose on the outlet of the vacuum,  inserted into the tank filler hole, to blow dry it out .
Once it's dry, I'll have a good look inside the tank with a small telescoping mirror, just to make sure there are no loose pieces of liner left in there, then it's on to the POR 15 kit .
« Last Edit: November 22, 2009, 01:37:18 PM by Bob_Roller »
Crossrodes
« Reply #28 on: November 22, 2009, 02:36:58 PM »
I wonder if Coca Cola will work.  I know it sounds like a myth but I knew a fellow in a boat yard in Trinidad who could not get his through hull fittings to close..they were totally corroded in the open position.  He tried all kinds of rust removers and as a last resort he tried Coke.  He left it 24 hours and voila the through hulls opened.  He then took them apart and they were clean as a whistle.
Has anyone tried coke in a gas tank.  If not I think I'll try molasses if I need to.
(Hey, maybe molasses is the secret ingredient in coke  :))
« Reply #29 on: November 22, 2009, 02:42:06 PM »
I don't have any Coke around the house, but if I'm not mistaken, it contains phosphoric acid .
Phosphoric acid is the final prep solution for the POR 15 kit, it's stated in the instructions, that it is for rust removal .
I bet with time, it would work as well .
