Author Topic: Project ... but, I'm in two minds  (Read 1154 times)
steve_wicks
« on: January 22, 2010, 08:42:09 AM »
I have just located a 1985 G/S (not sure if 800 or 1000, frame, dodgy engine, no tank ... but a host of odds and ends. I'm not sure what.
I suddenly thought, "ah, I've got a donor bike for that project' .... but I'm not sure if I want a bastardised G/S or whether I should stick to my idea of turning 'mutti' into a cafe racer ......???
Re: Project ... but, I'm in two minds
« Reply #1 on: January 22, 2010, 09:13:54 AM »
If you can get a good deal on it .
You can always part it out, afterwards if you change your mind .
« Reply #2 on: January 22, 2010, 10:19:23 AM »
Make that a REALLY good deal... if you decide to part it out on FleaBay.   Monte
steve_wicks
« Reply #3 on: January 24, 2010, 03:24:12 AM »
Help!! Does the gearbox/diff from a twinshock mount into an 85G/S frame. The one I can get my grubby paws on doesn't have the gearbox/diff assembly -
cost of the G/S is about US$ 1 300, but I think $700 or so might get knocked off.
larstorders
« Reply #4 on: January 24, 2010, 04:53:39 AM »
Twin shock diff is incompatible with the monolever system. It could only be mounted on a G/S if the rear sub frame and swing arm was converted to a twin shock. I don't know if that's easily do-able. Also, has different ratio. Twin shock gear box usually lacks kickstarter (although few people would bother about that) but different ratios here would also detract from the ride quality. Good luck
steve_wicks
« Reply #5 on: January 24, 2010, 06:02:13 AM »
Okay ... the fact that I'd have to source another diff makes it not worthwhile...... Oh, well! 'twas a nice fantasy while it lasted!
« Reply #6 on: January 24, 2010, 08:04:51 AM »
Hold onto the cash you've just saved, Steve. Be happy some knowledgeable peeps in the R65 Asylum kept you outta trouble. Another deal will pop up on of these days. [smiley=thumbsup.gif]
steve_wicks
« Reply #7 on: January 24, 2010, 03:23:19 PM »
.... it sounded nice for a while, but I'll stick with doing the cafe racer makeover
