Author Topic: Startup diagnosis  (Read 1578 times)
Offline BooG
Startup diagnosis
« on: January 04, 2010, 07:08:33 AM »
The epic continues!!
Now then...it appears that my non-starting issue could be due to the fact that the fuel is not reaching the cylinders. Squirts of carb cleaner during cranking allow some coughing and smoke from the pipes, so that tells me combustion is occuring...spark and compression therefore. The plugs, however, look dry after cranking. There is fuel in the float bowls, and I have had both carbs off for a clean and installed new diaphragms. Why would fuel still not be reaching the cylinders? I have checked the en-richeners on both sides for clear passages and correct installation. I must be overlooking something real simple.....??  [smiley=uhoh2.gif]
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Startup diagnosis
« Reply #1 on: January 04, 2010, 07:45:19 AM »
Just a SWAG here, but in one corner of the float bowl you will see a well that a brass tube fits in.  At the bottom of that well is a very small hole where the gas enters.  This hole can become easily clogged.  Take a dental pick or piece of wire and probe that to make sure it's clear.  It's not like a jet so you can't really harm it with the probe.  I had the same situation and that solved my issue.
Strange that neither cylinder is firing at all.  Make sure that you have the idle jet screw seated and then back off one turn for starters.  After you get ignition then go in an make the adjustments.  Let us know how it turns out.
« Last Edit: January 04, 2010, 07:45:43 AM by Bengt_Phorqs »
« Reply #2 on: January 04, 2010, 09:15:24 AM »
Here's what old Bengt is talking about. Had this issue on the left side of my '81. Cylinder would not fire until the right side warmed the engine and the carbs would pull fuel. A bit of fine dirt and fuel junk clogged it up. Cheap fix.
« Reply #3 on: January 04, 2010, 12:34:43 PM »
But both carbs at once?
« Reply #4 on: January 04, 2010, 12:46:05 PM »
Here's the email address to the Bing Agency, the only authorized outlet for for Bing Carburetors, for the America's, and OZ .
bing@bingcarburetor.com
They are usually quite helpful in diagnosing problems with Bing products .
Send them an email, and see what they have to say .
« Last Edit: January 04, 2010, 12:47:06 PM by Bob_Roller »
« Reply #5 on: January 04, 2010, 01:26:58 PM »
I know, I know. Not very likely but hey, Booger's tried most everything else. This little check cost nada. Like Bengt, it's just a SWAG.
Offline BooG
« Reply #6 on: January 04, 2010, 03:53:34 PM »
Cleared and blew those passages out on both sides. Nada!!
I'll e-mail Bing now and wait for a reply.
Thanks for the input!
BMW R65 1980.
BMW K75S 1987
Offline BooG
« Reply #7 on: January 05, 2010, 11:13:29 AM »
Here's my response from Bing; pretty much the same advice from y'all. Oh well, I'll whip em off and do it again!
Hi David,
I would start by checking the Start Jet, it is located in the float bowl.  There are two small circles in the corners of the bowl, one is plugged and the other is a well that accepts the brass pickup tube.  Some of the start jets are removable, they have a small screwdriver slot in them, others are fixed.  In any regard running a COPPER wire through this orifice will clean it and all fuel pickup.
If that is not the problem then make sure the Idle Jet,  Main Jet and the respective orifices into the body are clear and clean also, the same procedure works for both.
If all of the above checks out fine, there is a possibility that the choke disc are installed improperly.
If none of this helps give us a call at 620-767-7844 and we will try to assist you further.
Best regards,
Fay R. Laughridge, VP
Bing Agency International
620-767-7846
BMW R65 1980.
BMW K75S 1987
« Reply #8 on: January 05, 2010, 04:25:02 PM »
I had one item, that gave me problems, was the idle jet, it is inside the bowl area right adjacent to the idle mixture screw, that's outside the float bowl .
It has a slot for regular screwdriver to remove it .
The brass tube has two holes drilled in it, at 90 degree angles .
If you spray an aerosol carb cleaner from the screwdriver slot area, it looks like the part is clear of obstructions, but at the very end of it, the orifice can be clogged, and you may well not notice it .
This one gave me fits a few years back, when I did a complete 'overhaul' of both carbs .
« Last Edit: January 06, 2010, 03:10:22 PM by Bob_Roller »
