Author Topic: alternator or diode board or what?  (Read 5543 times)
GrimReaper
Re: alternator or diode board or what?
« Reply #30 on: January 05, 2010, 11:27:55 AM »
I talk with Rick again this morning and he suggest to buy a new multimeter.What a surprise  :othe new one shows 3.7 ohms.I guess my multimeter and my vdo gauge get broken in the same time. :)
  Thank you for your help guys
« Reply #31 on: January 05, 2010, 12:05:41 PM »
I had that problem, chasing a hard starting problem with my '81 R65, the meter I had, showed the proper resistance for the ignition coil, 1.5 ohms .
It was suggested that I get a known good meter to check out the coil .
I brought the coil to work, and checked it with a calibrated Fluke meter, and found the coil to have about a third of the resistance it should have .
Troubleshooting can get tough, when your test equipment isn't right !!!!!!
« Last Edit: January 05, 2010, 12:06:08 PM by Bob_Roller »
