Author Topic: Kisan signal minder  (Read 991 times)
williamemack
Kisan signal minder
« on: December 21, 2009, 03:37:30 PM »
I have a 1980 R65. Does anyone know which model Kisan fits?
« Last Edit: December 21, 2009, 09:08:36 PM by williamemack »
Re: Kisan signal minder
« Reply #1 on: December 21, 2009, 03:45:03 PM »
I think Semper Gumby has one installed on his '80 R65 .
I'm sure he will give you all pertinent info on it .
« Reply #2 on: December 24, 2009, 08:25:06 AM »
Hi WM,
Did you get my PM?
SG
williamemack
« Reply #3 on: December 25, 2009, 07:06:10 PM »
Yep, got the message. Thank you. I think I have moved the Kisan to the back burner.Mostly, I operate in a rural area and signal cancellation is not too much of a problem. I still think I'd go with it IF the switch would return to neutral all by itself.I know springs are offered by Kisan, but it seems they are not for our style switch.
In the meantime, I've found my Germa tank tap is malfunctioning. I have no reserve! I bet PO got the straws switched. Now that Santy's come and gone, I can pursue it tomorrow.
Best wishes for the new year.
Will
