Author Topic: R65LS Rear Wheel  (Read 851 times)
R65LS Rear Wheel
« on: December 17, 2009, 08:03:48 PM »
Can the R65LS rear wheel fit on the 1979-80 rounded final drive??
Has anybody done this?
Thanks in advance.
Re: R65LS Rear Wheel
« Reply #1 on: December 17, 2009, 09:13:46 PM »
The only thing I know for certain, is that the LS rear wheel brake drum is a larger diameter, so you need different brake shoes .
Standard R65 shoes won't work .
« Reply #2 on: December 17, 2009, 10:19:39 PM »
For some unknown reason I think that the wheel spacer/tophat bushing used in the LS wheel on one side is slightly longer than that used with the snowflake wheels.   But, if you've got a fully assembled wheel with the bearings and spacers, that is probably a non-issue.
Bill is right - the brake shoes are different, but I think everything else pretty much fits the same.
« Reply #3 on: December 18, 2009, 10:08:21 AM »
There are two different part number axles, one for bikes before 09/80, and another for bikes made 09/80 and later (twin shock bikes) .
I just saw, that the LS version, has a different part number from the other two .
« Last Edit: December 18, 2009, 10:58:48 AM by Bob_Roller »
