Author Topic: The R65 and the circlip-less transmissions  (Read 1494 times)
Adamastor
« on: November 21, 2009, 08:10:16 AM »
Hi there!
I have been reading all of airbum's web site and there is a special section devoted to one specific problem on bmw transmissions:
http://bmwmotorcycletech.info/transmission.htm
During some years, BMW omitted a circlip on some transmissions, wich can and probably will result in catastrophic destruction of the transmission box.
I have checked my gear box serial number and it seems to be in the "dangerous" zone: Z-113177, a 1985 gear box.
Have you guys have had any problem with this? If you are supposed to have one of the circlip-less boxes, what can you do?
Regards,
Sergio
Re: The R65 and the circlip-less transmissions
« Reply #1 on: November 21, 2009, 08:25:51 AM »
The transmission needs to be removed from the bike, opened up, and I think, the output shaft needs to have a groove  machined to accept the circlip .
I had my transmission overhauled  2 and a half years ago, mine didn't have the circlip installed, so the shop did the machining and installed the clip before reassembly .
My transmission had 78,000 miles on it, at the time .
Adamastor
« Reply #2 on: November 21, 2009, 10:18:29 AM »
They are an accident waiting to happen, right? But snowburn says if you do those small tests periodically you can predict more or less when it needs work..
I had so much work on the R65 so far that I do not want to stop riding it right now... maybe next year I ask a quote on a specialized airhead mechanic here in Portugal...
Oh boy..
I always felt a grind from 1st to 2nd and 2nd to 1st gears (goes away if I stop by neutral), but I thought it would be normal on a high mileage bmw, now I wonder if it really is normal...
« Last Edit: November 21, 2009, 10:19:51 AM by Adamastor »
GrimReaper
« Reply #3 on: November 21, 2009, 11:31:10 AM »
Who did the overhawl Bob?What was the cost for it?
« Reply #4 on: November 21, 2009, 11:59:15 AM »
I had Motorworks in National City, CA (San Diego area) do the overhaul .
I don't have the bill handy, but I believe it was around $650, that included all of the bearings, bushings, gaskets, seals, shifter pawl spring, and the circlip installation .
That did not include shipping, I took the transmission to them,  then went back to pick it up a few weeks later when it was done .
There were no additional problems with the transmission, prices go up from there .
I had some issues with the transmission after the overhaul, the shifter shaft seal was installed really crooked, causing shifting problems .
I had a few email conversations with 'Oak' Okleshen airheads technical expert, and he told me he has seen overhauls done by Motorworks, and the quality of workmanship was not the greatest .
So I can't give them a good recommendation, but a friend of mine that lives in San Diego, says I'm one of the few people he has heard about, that has had problems with their work .
« Last Edit: November 21, 2009, 12:00:21 PM by Bob_Roller »
