Author Topic: Bike Throttling Uo  (Read 1142 times)
Crossrodes
Bike Throttling Uo
« on: November 13, 2009, 03:34:15 PM »
I took the R65 out to lunch today and had a problem with the bike revving up to 4000 at idle and when riding.  I first noticed it when riding along and when I throttled down it would not reduce revs.  I blipped the gas several times with the clutch in and sometimes it would work to reduce revs and sometimes it would not.  At another point I was sitting at a light in neutral and it started to rev right up to 4000.  This hap pended several times.
When riding and this happens I noticed it would sometimes reduce rpm if I had the clutch in and hit the brakes????
A couple of days ago when the bike was running fine I had a 50 km ride in the rain and I also put some Chevron Techron in the tank to clean our the fuel/combustion system.
Any thoughts?
Re: Bike Throttling Uo
« Reply #1 on: November 13, 2009, 03:56:19 PM »
First thought, would be the throttle cable system is hung up .
Second would be the centrifugal advance mechanism in the 'bean can' is stuck in the advance position .
« Reply #2 on: November 13, 2009, 04:54:27 PM »
Check the diaphragms !!! fuel additives are dodgy
« Reply #3 on: November 13, 2009, 05:59:02 PM »
Dang but you guys are good! great advice covering all potential problem areas. Props to Bob and Lucky Lou.   Monte
Crossrodes
« Reply #4 on: November 13, 2009, 07:37:38 PM »
Thanks guys.
I'm thinking cables or diaphragm.  I changed the cam seal and cleaned up the bean can this summer.  Oh well, time to put her away and maybe take her apart.  I wasn't planning on doing the carbs but I guess I'll spring for a kit from Bing this winter.
The fact that it sometimes throttles down when I apply the front brake is puzzling though.  I was wondering if I could have something that is obstructing the flow of gas in the tank and when I apply the brake the inertia moves the obstruction and allows the gas to flow again...just a thought.  What do you think?
« Last Edit: November 13, 2009, 07:40:45 PM by Crossrodes »
« Reply #5 on: November 13, 2009, 08:09:11 PM »
There's enough fuel in the carb bowls, and the fuel lines to run the engine for a couple of minutes, so I don't think it's a fuel delivery issue .
