Author Topic: No Crossover Tubes  (Read 1139 times)
No Crossover Tubes
« on: October 27, 2009, 06:27:18 PM »
I have a set of headpipes that have had the crossover tube connectors removed and welded over. I was thinking of installing them and wondered if anyone has any comments, yes or no, about doing this. Any benefits, drawbacks, performance issues, etc.?
Re: No Crossover Tubes
« Reply #1 on: October 27, 2009, 06:33:25 PM »
From what I can remember, the crossover tubes helped the mid-range power band .
Don't know in reality, if you would notice a difference or not in the performance level of an R65 or not if the tubes weren't there .
« Reply #2 on: October 28, 2009, 04:42:19 PM »
I'm pretty sure the bike will run stronger with the crossover.
They even added a second crossover in '81 for additional boost.
bruce_launceston
« Reply #3 on: October 29, 2009, 05:41:48 AM »
I've been running my LS 2 into 2 without any balance pipes for about 20 years.
I've never felt the need to weld them back in, it runs fine as it is with it's custom made mufflers.
« Reply #4 on: November 01, 2009, 09:13:23 AM »
bruce, the difference in your muffler backpressure might be helping you.  Every case I've read about when someone removed the crossover from an otherwise stock exhaust system performance suffered.
