Author Topic: Is this due to bad Flasher relay?  (Read 892 times)
Offline R65Singh
« on: October 27, 2009, 04:33:14 PM »
Hello All;
The turn signals on my bike have been acting lately.  They start and stop working at will.  When they are NOT working...and I push and hold the high beam switchdown they will work as long as the high beam switch is held down.
I checked the flasher relay and cleaned all the connections but no luck so far.  Could it be the turn signal switch itself?
Also I cant find the turn signal buzzer (if there was one the bike originally came with) that is operated by the switch in the clutch lever.  Can any one can post a picture of it (what it looks like and where exactly it sits).  This board has been a great source of help and I know someone will nail it right away.
1982 R65LS
1970 r50/5
1962 r50/2
1976 Honda Z50
Re: Is this due to bad Flasher relay?
« Reply #1 on: October 27, 2009, 05:00:56 PM »
There are no electrical connections between the headlight switch, and the turn directional switch .
When you hold the head light switch into the flash position, you may be pushing a broken part together in the turn directional switch, allowing it to operate .
« Reply #2 on: October 27, 2009, 05:03:07 PM »
I'm pretty sure the '81-on bikes did not have the buzzer.
As for your other problem, just as a start, I would look for a broken ground wire, somewhere.  The main grounds are brown.  I think secondary grounds are brown with a colored stripe on them.
How does the T.S. switch feel when you are working it?  It should be smooth and tight.
« Last Edit: October 27, 2009, 05:04:44 PM by Rob_Valdez_79_R65 »
Offline R65Singh
« Reply #3 on: October 27, 2009, 06:10:36 PM »
Thanks Bob and Rob .  I will look at the switch tonight.  As far as the toggle action of the switch goes, it is very nice and smooth to operate...but I will clean it up again and see how it goes.  Will keep u guys posted. Thanks for the help.
1982 R65LS
1970 r50/5
1962 r50/2
1976 Honda Z50
« Reply #4 on: October 27, 2009, 07:04:33 PM »
All of the ground, or earthing wires are solid brown, if they have a spiral band around them, it's for another electrical circuit .
At least for the twin shock model bikes .
