Author Topic: CRANKCASE LOCATING PINS. REPLACEMENT.  (Read 2935 times)
AH1510
« on: October 20, 2009, 03:22:19 PM »
Hello from the sunny left coast.  Can the location pins for the crankshaft trust washers and shims be replaced? I found a bent one. Thanks. OLDPAUL.
Re: CRANKCASE LOCATING PINS. REPLACEMENT.
« Reply #1 on: October 20, 2009, 04:28:27 PM »
I could be mistaken, but the few pictures I've seen of the locating pins, they appeared to be cast into the engine case .
« Reply #2 on: October 20, 2009, 06:19:30 PM »
A bent what, thrust bushing?  These are easy for people to mangle up if they forget to block the crank before removing the flywheel...
« Reply #3 on: October 20, 2009, 06:30:34 PM »
I have a 1980 short block languishing in my garage.  Your's for shipping.
AH1510
« Reply #4 on: October 21, 2009, 09:43:16 AM »
Hello Rob,
                   I will keep you mind about the short block. I will know more when I get the crank out. OLDPAUL. :)
« Reply #5 on: October 22, 2009, 06:15:23 PM »
Hello Rob,
Send me an email, if you are.  I check that more often than the forum.
AH1510
« Reply #6 on: October 23, 2009, 10:37:37 AM »
Hell Rob,
                 Will do. Thanks. OLDPAUL. :)
