Author Topic: Liquid sealant as oil pan gasket - a no no ?  (Read 1780 times)
Adamastor
« on: October 14, 2009, 09:15:45 AM »
In order to inspect and clean, I removed the oil pan from my R65. I have a quality (Nural 60) liquid gasket sealant at home, could it replace the normal paper gasket?
Besides that, using these lock washers is also a no no?
Thanks..
Re: Liquid sealant as oil pan gasket - a no no ?
« Reply #1 on: October 14, 2009, 10:42:44 AM »
How tight of a bond does the sealant have ?
With no paper gasket, it may be quite difficult to remove the oil pan at a future time .
I'm not sure how deep the threaded holes in the engine block are, without the gasket, the bolts may bottom out before tightening up the oil pan .
Those lock washers may tear up the metal of the oil pan, it's just a soft aluminum casting, not steel .
Adamastor
« Reply #2 on: October 14, 2009, 11:25:04 AM »
Thanks for the opinion, I will cut a new paper gasket for it.. (I have a roll of good thick gasket paper) maybe it is better... and forget about those lock washers... thanks :)
drewboid
« Reply #3 on: October 16, 2009, 11:25:21 AM »
Many have had success with the silicon gaskets from
http://www.realgaskets.com/files/motorcycle.htm
Aircraft quality and reusable - if you don't mind the red/orange color they are great.
Yikes
« Reply #4 on: October 16, 2009, 12:03:19 PM »
Seems like the silicone gaskets would be good to get for the valve covers anyway.  I find myself pulling them off fairly frequently to adjust and tinker and that tends to do in my paper gaskets fairly quickly. :(
Those silicone gaskets ain't cheap, but then neither are those paper gaskets.  Could be a savings in the long run.
« Reply #5 on: October 16, 2009, 04:16:14 PM »
Try coating them with Copperslip or a HT lube should be reusable.
« Reply #6 on: October 17, 2009, 05:29:39 PM »
love the silicone valve cover gaskets! The oil pan gasket is a bit different though. There I like to use the OEM item as it doesn't have to come off for adjustments like the valve cover. Also it is a bit thicker than the average gasket paper stock I've seen around.
