Author Topic: R65 and R50/5  (Read 1396 times)
R65 and R50/5
« on: September 20, 2009, 12:31:13 PM »
Hi ive been asked if the Krauser panier frame fitted to the r65 will fit a r50/5 i think it will does anyone know for sure??
 ta Lou
drewboid
Re: R65 and R50/5
« Reply #1 on: September 22, 2009, 08:04:50 AM »
The frame may be the right length if it is for the short wheelbase /5 but I have heard that the lower mount for the R65 is horizontal where it attaches to the frame and the /5 is oriented vertically. Not sure but you need to check carefully.
Re: R65 and R50/5
« Reply #2 on: September 22, 2009, 08:37:36 AM »
+1 with Drew - the lower mounting hole that bolts on next to the passenger footpegs may be the sticking point, though maybe you can fabricate an "L" bracket that would handle the directional change required if there is enough space ?
