Author Topic: Clutch actuating arm inner bearing  (Read 828 times)
mimmo66
« on: September 11, 2009, 08:09:33 PM »
After many miles (45K) I finally found out how to fix the annoying sticky clutch I was experiencing.
Inside the arm operating the clutch there is a needle bearing rotating around a steel sleeve where the retaining bolt goes in.
I found my sleeve to have little scoring matching the needle bearing, hence the stickiness.
I polished it on wire steel wheel, repacked with some grease.
Hopefully it 'will do the trick for awhile until replacement is due. [smiley=bmw_smiley.gif] :) :) :)
Re: Clutch actuating arm inner bearing
« Reply #1 on: September 13, 2009, 09:06:58 AM »
This is called the throwout bearing service which should be done everytime you do the infamous spline lube.
You have done a spline lube right? :o
mimmo66
« Reply #2 on: September 13, 2009, 10:45:42 AM »
I try to spline lube once a year, this winter when I get to it I'm planning on replacing the throw out bearing with a new one.
Test rode it yesterday and it seems much better now.
How much do you tighten the bolt securing the clutch lever? I just go by feel, not too tight, just snug.
Thank you, Domenico
« Reply #3 on: September 13, 2009, 10:59:00 AM »
Up on the handle bars?  I guess just snug so it doesn't pinch the handle and keep it from moving I guess.
< He has no clue >   :-[
