Author Topic: Fork Rebuilds  (Read 3026 times)
ambrose78
Fork Rebuilds
« on: August 13, 2009, 08:54:20 PM »
Well it is coming time to do a fork rebuild -
1 - in an attempt to narrow down the mild wobbling.
2 - One of the tubes is suffering from black oily lines
Having poked around on motobins to try and order some parts, they appear to carry kits for all the r series bikes except the R65/45.
Do any kits exisit? Do the r65's need a kit at all?
Re: Fork Rebuilds
« Reply #1 on: August 13, 2009, 09:50:36 PM »
There are only 5 parts per fork that are considered 'consumables' on an R65 .
Have never seen a kit before .
At the top plug, there is an o-ring, the large oil seal that fits into the top of the lower fork leg, a plastic bumper inside the damper assembly, a crush washer for the bolt at the bottom of the lower fork leg that holds the damper in place, and a copper crush washer for the drain plug on the backside of the lower fork leg .
« Last Edit: August 13, 2009, 09:53:10 PM by Bob_Roller »
Re: Fork Rebuilds
« Reply #2 on: August 14, 2009, 03:16:15 AM »
None of the UK suppliers list parts for R65/45. The polyurethane topping out bush is available though not listed for the R45/R65 it fits. Other than that you only need fork seals which are avaialable and maybe the crush washers. If you can't get new crush washers you might get away with anealing them. The washer on the damper rod bolt at the bottom of the fork has to seal well because it keeps the oil in so this has to be reasonably good otherwise any small fibre washer that fits would probably be ok for the drain screws.
What year is your bike ? There were several changes to the damper valve assembly in the early years.   If it's a 78 - 80 you may need to shim it.  The usual parts fiche sites will show the differences.
« Last Edit: August 14, 2009, 03:35:26 AM by bhodgson »
Re: Fork Rebuilds
« Reply #3 on: August 14, 2009, 03:56:26 PM »
Last time I cleaned out and added new seals to the 81's forks, I don't recall seeing the nylon (?) bushing pictured in Barry's posting. That has left me in a quandary.
Referring to the A&S diagram:
http://www.ascycles.com/Illustrated_catalog/R65(78-85)/catalog_frameset.html
What item number is the plastic bushing? I need to refresh the seals in the '83 and I'll bet the bushing may be missing in that bike also. Better order four!
Re: Fork Rebuilds
« Reply #4 on: August 14, 2009, 04:04:38 PM »
I think it's reference item # 24 .
I know my bike is missing them, never saw them when I took it apart, and didn't know I needed them until about a year after I rebuilt mine .
If some one can show  the proper installation of this part, as my '84 LS needs the forks gone through, and I won't mess it up this time !!!!!
Re: Fork Rebuilds
« Reply #5 on: August 14, 2009, 04:48:32 PM »
Yes it's item 24 and fits immediately under the damper piston.  In practice you push it into the lower stanchion before inserting the valve plate, valve washer and valve body in that order.  Dimensions are 28mm OD  18mm ID and 7.75mm thick.  The Motobins replacement was a few thou bigger (sorry for the mixed units but I can't visualise a few thou in fractions of a mm) than 28mm OD so was a slightly tighter fit than the original.  The other dimensions are not critical as the bore is 2mm larger  than the piston rod and the 7.75mm thickness only affects the fully extended length of the forks when the bikes on the stand.
The original bushes were black rubber so may have disintegrated. Mine were quite brittle.
Re: Fork Rebuilds
« Reply #6 on: August 14, 2009, 05:18:45 PM »
The original parts were black rubber, that explains the black goo that was in the forks, when I took them apart .
Re: Fork Rebuilds
« Reply #7 on: August 14, 2009, 06:28:07 PM »
I'm going for the Motobins hookup. Thanks, guys, for the solid info. [smiley=thumbsup.gif]
ambrose78
Re: Fork Rebuilds
« Reply #8 on: August 16, 2009, 07:00:18 PM »
Cheers for the info.
My bike is a november Build '81.
So are these the correct parts to order?
29020 nylon ring
93904 rubber oil seals
oring
washer
and a couple of crush washers
I was also thinking about adding some gators to protect the upper seal and stauncions
Peter
Re: Fork Rebuilds
« Reply #9 on: August 16, 2009, 07:06:58 PM »
The rubber dust cap, that goes over the fork seal area, has a piece of felt that fits into a groove, and acts as a wiper on the fork tube .
The gaiters need a narrow clamp to secure them, a normal cooling system hose clamp won't work, it's too wide .
« Last Edit: August 16, 2009, 07:11:56 PM by Bob_Roller »
ambrose78
Re: Fork Rebuilds
« Reply #10 on: August 16, 2009, 07:26:34 PM »
Hi Bob,
I don't quite understand what your mean - Does the dust seal come with a felt seal or do I have to order one?
Would the gators work with zip ties?
Re: Fork Rebuilds
« Reply #11 on: August 16, 2009, 07:29:32 PM »
The felt strip is a separate part, but if you going to install gaiters, the rubber cap comes off, as the gaiter won't fit with it installed .
ambrose78
Re: Fork Rebuilds
« Reply #12 on: August 16, 2009, 08:08:45 PM »
Gotcha.
Thanks.
Re: Fork Rebuilds
« Reply #13 on: August 16, 2009, 09:47:20 PM »
Pete,  This is the "felt" wiper that tucks inside the OEM rubber boot. It's oiled after install in the boot and serves as a dust wiper. With gaiters, the boots and felts are not needed.
Don't forget to order the fork "seals". Please confirm all part numbers with Motobins or your agent prior to ordering.   Monte
ambrose78
Re: Fork Rebuilds
« Reply #14 on: August 16, 2009, 10:03:58 PM »
Thanks for that Monte,
I will just stick with the felts and boots.
