Author Topic: valve guides  (Read 994 times)
the_admiral
valve guides
« on: August 01, 2009, 01:12:56 PM »
hi all again,i am am in the process of fitting new exhaust valve guides on my 81 r65 and i am just waiting for them from motorworks.the old one have come out quite easily with a bit of gentle heat.has anyone got any good tips on reffiting the new ones,i was going to heat the head and put the guides in the freezer overnight.any ideas on a suitable drift so as not to damage them,thank peter
Re: valve guides
« Reply #1 on: August 01, 2009, 02:53:03 PM »
The heat and freeze method should work good and maybe tap 'em in with a plastic or rawhide mallet.
Re: valve guides
« Reply #2 on: August 01, 2009, 06:55:49 PM »
A valve guide drift fits down inside the guide to prevent damage....they came in various sizes.If you know someone with a lathe they could turn one up easy enough.But they should tap in no problem.
weasel01
Re: valve guides
« Reply #3 on: August 02, 2009, 04:49:06 PM »
Yo Admiral, what caused the need to replace them?
Just curious?
the_admiral
Re: valve guides
« Reply #4 on: August 03, 2009, 04:22:27 PM »
hi thanks for the advice guys,
Amplifier i am replacing them because when checking the tappets there was a fair amount of play side to side on the exhaust valve guide and this could lead eventually to a dropped valve,also she was a bit smokey on start up,cheers
 ps any tips on posting pics anyone
