Author Topic: Should i worry about this  (Read 847 times)
« on: July 19, 2009, 02:25:36 PM »
There are two holes drilled in the main engine casing one near the dip stick and one on the opposite side in a similar position.......im getting a slight oil mist appearing around it ??? there's no loss of power or anything else the oil level doesn't  seem to be dropping so should i be worrying about it ?
« Last Edit: July 19, 2009, 02:26:33 PM by Lucky_Lou »
Offline beemer
  • The Red Tomato!!!
Re: Should i worry about this
« Reply #1 on: July 19, 2009, 02:53:22 PM »
They are for replacement knee lubrication as you ride along!!! 8-)
« Reply #2 on: July 19, 2009, 03:29:23 PM »
BMW think of everything how did they know my right knee is in need of constant lubrication???
« Reply #3 on: July 19, 2009, 03:32:00 PM »
They are drain holes for the starter "cavity".  Possibly your crankcase breather hose (which runs through there) might have a crack?
« Reply #4 on: July 19, 2009, 04:03:34 PM »
Thanks there the origonal hoses ill whip the cover off and check em though they looked ok when i did the rebuild,
