Author Topic: Voltmeter on R65?  (Read 761 times)
TXRider60
Voltmeter on R65?
« on: July 10, 2009, 07:56:03 AM »
Re: This ad from IBMWR Marketplace... Has anyone installed a voltmeter on their R65... And was it helpful..? On my last Japanese motorcycle I had one of the little LED (red-yellow-green) devices, and it providede the illusion of security on the road...
                                    volt meter
used volt meter off an r100. green color face and comes with bracket.
Price: 40
Contact rob spiess at <spyrs@verizon.net>
Posted Thursday, July 09, 2009 at 22:41:54 (EDT)
THANX!
Re: Voltmeter on R65?
« Reply #1 on: July 10, 2009, 11:12:47 AM »
The stock voltmeter gets pretty bad press as being inaccurate.  I don't know if this is the fault of the meter or how it is wired in.  It need to run off a switched 12V source so I guess it's possible that all of the connection resistance in the circuit could cause it to read lower than it should.  A good approach to get full battery power to a meter would be to use a relay that is actuated only when the switch is in the "ON" position and having the relay shoot straight "battery" voltage to the meter.
