Author Topic: moving on...timing?  (Read 2427 times)
weasel01
moving on...timing?
« on: July 04, 2009, 12:07:49 PM »
I am on my way to harbor freight to buy a timing light.
Is this tool sufficient or do I need something better?
Re: moving on...timing?
« Reply #1 on: July 04, 2009, 12:14:49 PM »
I'm sure that HF has more than one timing light so I can't comment unless you are more specific.  A SKU number would be helpful...
weasel01
« Reply #2 on: July 04, 2009, 12:58:35 PM »
« Last Edit: July 04, 2009, 12:59:15 PM by weasel01 »
« Reply #3 on: July 04, 2009, 04:47:08 PM »
It should work although I don't think you'll get much use out of the timing advance feature.  Just a straight inductive-pickup timing light (Xenon of course) that would suffice.  Like this 'un...
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3343
But, I guess it all boils down to which one your local store carries.
« Last Edit: July 04, 2009, 04:50:12 PM by admin »
weasel01
« Reply #4 on: July 05, 2009, 08:59:40 PM »
I bought the cheaper of the 2 and it works but the strobe isn't all that powerful but it does work.
I am still obsessing over the timing hole marks....
My bike has the this for the advanced timing mark   :
     _
     Z
The mark on my timing hole is on the lower left hand side.
Do I adjust for the mark on my case to the line above Z or between the line and the Z or centered on the Z?
Also which plug wire... snowbum says it doesnt matter but the left is more convenient the manual say the right hand I tried both and there is a difference.
I went with the right hand but now my valve noise seems to be louder?
« Reply #5 on: July 05, 2009, 09:37:56 PM »
     _
     Z
I use a high-dollar Sun xenon timing light and the light ain't too bright either. Plus, cables get in the light beam and my eyes aren't far enough apart to see around 'em.::)Usually, I'll close the shop overhead door, leaving it just cracked so I don't off myself, and get a slightly better image from the timing light.
At approx 3500 rpm, the ignition should be fully advanced and the horizontal mark above Z should be centered in the hole. At idle rpm, the S mark should be centered in the hole. If S is low in the hole, the timing is retarded. S high, too advanced.
I use the right-hand plug lead for timing, per the manual. A good fan blowing straight on the front end of the engine helps prevent overheating it you dawdle too long.
When you're happy with the timing, and the BMW accepts quite of bit of tolerance, let the engine cool and re-check valve lash.
weasel01
« Reply #6 on: July 05, 2009, 09:46:00 PM »
Thanks Monte! On that same note as I recheck the gap at the valves the
TDC has a line above it too....    __
                                               ot
Where in reference to the mark on the side of my timing hole?
« Reply #7 on: July 05, 2009, 09:51:05 PM »
Same. The letters just tell you what mark you're looking at. The line is your guidon.   M
weasel01
« Reply #8 on: July 05, 2009, 10:10:34 PM »
So line the line up in the center of the hole or with the notch in my case which is on the lower part of my timing hole off center?
« Reply #9 on: July 06, 2009, 06:10:27 AM »
Should be the factory notch. Mine's pretty much on center but I suppose the factory may adjust as necessary.
« Reply #10 on: July 06, 2009, 08:56:38 AM »
If you subscribe to the BMW MOA Owners News there is a very good article in this months issue on the description of all the timing marks on the airheads.  Also, I've been told to hook up the timing light to an auxiliary battery as the bike battery could give you a false reading.  Don't know if this is true but it worked very well for me.
« Reply #11 on: July 06, 2009, 11:13:08 AM »
Good call on the aux batt, Mike. I failed to recall that little bit. I do that with my bikes and feel it's a better timing job. Snowbum discusses this, too... so what else is new?
« Reply #12 on: July 06, 2009, 11:16:56 AM »
I put a Sears battery charger on the bikes battery, when I do the carb adjustments, or any other time the bike is going to be running, and not charging the battery properly .
« Reply #13 on: July 08, 2009, 02:19:38 PM »
I have always clipped to the vehicle battery and never had any problems.  NOW, since you goobers have pointed out that my way is wrong, I will probably no longer be able to use the vehicle battery.  Thanks a lot...
« Reply #14 on: July 08, 2009, 02:29:48 PM »
Aw, Justin. You're just still ticked off 'cause you didn't get to go ride The Dragon and we're paying for it. [smiley=furious3.gif]
