Author Topic: inside Harness diode  (Read 1050 times)
billygoat
« on: July 01, 2009, 03:08:53 PM »
 I need to replace the diode here, can get one for $.50 which is cheaper that the $17+ A&S wants
http://farm3.static.flickr.com/2551/3679575954_c35f0bed5c_b.jpg
Re: inside Harness diode
« Reply #1 on: July 01, 2009, 04:09:15 PM »
The diode, is it for the hazard flasher system ?
Had mine go bad about a year ago, went to Radio Shack, and got a package of two for around $1, alot more cost efficient than BMW OEM parts !!
billygoat
« Reply #2 on: July 02, 2009, 12:40:04 AM »
 It's part number 3 in this pic. I hope it works. Part number-61311358268
http://www.maxbmwmotorcycles.com/fiche/DiagramsMid/B0001752.png
« Last Edit: July 02, 2009, 12:40:46 AM by billygoat »
ambrose78
« Reply #3 on: July 02, 2009, 03:34:31 AM »
I had that give out on me a few months ago.
I bought a pack of 5 diodes for A$1 for the electronics store.
Took about 10 minutes to measure cut, clean and solder the new one in - just note the direction "band".
If you are in the mood for soldering probably a good opportunity to use the left over diodes to replace the other small diodes (thankfully all the same rating) on the bike such as the neutral light diode in the starter relay as they all seem to wear out about the same time.
good luck with it.
Offline beemer
  • The Red Tomato!!!
« Reply #4 on: July 02, 2009, 04:31:23 AM »
Iv'e never found a hazard flasher system on my 83 R65LS,where is it?
« Reply #5 on: July 02, 2009, 07:09:52 AM »
It was an OEM factory kit , only ones I've seen were on eBay .
I got mine about 4 years ago, for $35US plus $15 shipping from Germany, the seller is S. Meyer .
