Author Topic: Gunson's colourtune?  (Read 2170 times)
Offline beemer
  • The Red Tomato!!!
« on: June 30, 2009, 03:42:25 AM »
Has anyone ever used a Gunson's Colour Tune to set the mixture on the R65?is so,how as it?
Re: Gunson's colourtune?
« Reply #1 on: June 30, 2009, 06:38:31 AM »
Don't recall the manufacturer's name but I had a ColorTune way back in the day. I attempted to figure it all out but finally quit trying. Not sure if it was Snake Oil or not.   Monte
ukzknos
« Reply #2 on: June 30, 2009, 07:00:38 AM »
Hi Beemer
Yes I have one and, in conjuction with balanced carbs gives superb results!
Highly recommended  :)
I think they are still available at Halfords for about 20 quid.
Offline beemer
  • The Red Tomato!!!
« Reply #3 on: June 30, 2009, 09:40:30 AM »
Hi Beemer
Thanks for  that,is it the standard model you need?or something just for motorcycles?
ukzknos
« Reply #4 on: June 30, 2009, 10:15:39 AM »
Beemer
It is the 'standard' 14mm plug version, see link:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_189330_langId_-1_categoryId_165557
Good old airheads with 14mm plugs as the 12mm &10mm plug colortune are more expensive!
Offline beemer
  • The Red Tomato!!!
« Reply #5 on: June 30, 2009, 10:27:18 AM »
Beemer
I have one of these!!had it for years,not sure if it's the Gunson's 500 model which has a tapered thread i believe,it's quite short,and i was wondering if it might blow out!!which one do you have?
« Reply #6 on: June 30, 2009, 11:08:36 AM »
I have what I believe is an older version of the Colortune .
It doesn't have what looks like the white ceramic insulator from a spark plug, over the clear glass viewing window .
Mine arcs across the glass surface, and 'shorts out' the ignition on the cylinder that it is installed in .
I've tried RTV type sealants over the center electrode where it goes into the glass, but still can't stop the arcing .
So be sure you get the newer model .
Offline beemer
  • The Red Tomato!!!
« Reply #7 on: June 30, 2009, 06:03:39 PM »
Mine actually has the ceramic insulator,so should be ok,i might give it a go tomorrow.
Offline beemer
  • The Red Tomato!!!
« Reply #8 on: July 01, 2009, 06:41:13 AM »
Used the colortune this morning,what a great item this is,one carb was ok,the other slightly off!!!after adjustment,that nice blue colour shown in both pots, both are running in harmony,balanced the carbs afterwards and the job is a "good un". :)
« Reply #9 on: July 02, 2009, 12:44:44 AM »
I have two Colourtunes....different models,but both work.I used then to set up twin cyl motorcycles.I haven't used them on the R65.....but will do if I want to set the idle again.
