Author Topic: LS muffler restoration?  (Read 1252 times)
Offline Cdngs
« on: June 26, 2009, 09:07:40 PM »
Hey, I'm nearing the end of my 82 LS restoration project. My plan is to have a nice ridable LS not a museum piece.  I just picked up a great set of used black mufflers and pipes. They are not rusted at all, but the finish is black faded and worn in some spots. Does anybody have a suggestion for repainting. I need it to be DIY, as Im working on a budget.
Thanks
« Last Edit: June 27, 2009, 09:11:20 AM by admin »
Re: LS left muffler?
« Reply #1 on: June 27, 2009, 09:07:00 AM »
[movedhere] Trading Post [move by] Justin B..
I have used Eastwood's Satin Black Exhaust Coating with good results.
http://www.eastwoodco.com
« Last Edit: June 27, 2009, 09:13:19 AM by admin »
Re: LS muffler restoration?
« Reply #2 on: June 27, 2009, 11:08:09 AM »
I gave mine a light sanding and careful cleaning and used Dupli-Color high temp flat black. I also let them bake in the desert sun for about a week before I put everything back on. The result is good and the paint has held up for a year so far. You might try the satin black Justin used for a more authentic finish.
« Reply #3 on: June 27, 2009, 04:53:55 PM »
I used POR-15's hi temp engine paint called "Black Velvet" - it is somewhat flatter in color than the satin black paint that Justin used.  Expensive, but you'll probably get several complete exhaust system coatings our of a pint.    I think that it will require repainting every few years to avoid rust..
