Author Topic: Side Stand Options?  (Read 8627 times)
R65_Mark
Re: Side Stand Options?
« Reply #15 on: April 25, 2009, 07:36:13 PM »
Ed,  Thanks for the pictures, they're going to help everyone understand what the Surefoot option looks like.  I'm heading this way.  Just need to get organized.
Now, if someone can post picture of the Brown, we'd all be able compare/contrast.
Mark
« Reply #16 on: April 25, 2009, 08:31:53 PM »
Here's one on a '95 R100RT, looks/works the same on an R65...
« Reply #17 on: April 25, 2009, 08:40:16 PM »
Justin - in that photograph it seems like you still have the OEM sidestand on that RT as well??   Are you one of those "belt and suspenders" kind of guys?
« Reply #18 on: April 25, 2009, 09:14:09 PM »
No, just lazy...
« Reply #19 on: April 26, 2009, 08:22:15 PM »
No, just lazy...
Gosh! Doesn't everyone enjoy pulling the freakin' exhaust system just to add a shim washer to the sidestand pivot? Or remove it?  ::) Monte
R65_Mark
« Reply #20 on: May 22, 2009, 08:22:01 AM »
I ordered a Surefoot side stand from Motobins today.  I'll pick it up while I am in the UK late next week.  When I get back home, I'll take and share pictures pre, during and post installation.  Thanks.  Mark
Offline beemer
  • The Red Tomato!!!
« Reply #21 on: May 22, 2009, 03:54:47 PM »
Has anyone modified the original stand in someway to get it to work better?cut and welded it for instance?let's hear about it! ;)
steve_wicks
« Reply #22 on: May 22, 2009, 04:54:42 PM »
To get a alternative side stand here in South africa will cost me about US $250
I can order one from England, not sure what make, but it costs 53 pounds ....... then shipping is a whopping 25 pounds.
dbilik
« Reply #23 on: May 26, 2009, 05:14:45 PM »
Just finished installing new SureFoot. This newbie would have appreciated a time-saving hint that the mount was a through bolt and not a stud. Thanks!
R65_Mark
« Reply #24 on: June 02, 2009, 07:18:32 PM »
Dori & Others, I picked up my Surefoot while in the UK this past weekend.  It looks OK (see pictures) but as Dori says, no instructions.  If anyone has any tips, I'd like to have them.  I plan to tackle the job this weekend.  Mark
« Reply #25 on: June 03, 2009, 12:53:36 AM »
If it's like the Brown it will attach via the rear "motor mount" stud.  The little loop looking gizmo on the end, I'm guessing, goes around the frame.  I kind of like that a bit better then the Brown where you relocate the exhaust pipe hanger to the front of the stand bracket...
I think I'd like to combine the two, the basic Brown sidestand with the "loop gizmo" from the SureFoot.
bruce_launceston
« Reply #26 on: June 03, 2009, 02:55:33 AM »
Interesting thread, Can someone please tell me what the main issues are that people are having with their standard side stands?
Cheers Bruce
« Last Edit: June 03, 2009, 02:56:55 AM by bruce_launceston »
« Reply #27 on: June 03, 2009, 03:20:45 AM »
Mine collapsed and caused the bike to fall over in the garage.
Against a load of push bikes.  I have several dents in my tank now. >:( - £200-300 for a respray.
When it starts to lean over a bit far, get shot of it before it lets you down.  The jaws of the stand broke, rather that the tang on the frame.
I have a surefoot now.  Excellent.
« Last Edit: June 03, 2009, 03:21:45 AM by steve_hawkins »
« Reply #28 on: June 03, 2009, 10:12:02 AM »
Cheers Bruce
My factory stand poked out too far when up, and dragged on left hand corners.  I hate when that happens.  The Surefoot does not (well, not yet).
« Reply #29 on: June 03, 2009, 10:15:11 AM »
I think this is one product that probably doesn't need instructions, if you go out and hold it up to the bike.  Put the bike on the center stand, get your existing side stand out and out of the way.  Remove the nut and washer on the left side of the rear motor mount, offer up the Surefoot stand on that nut with the hook cupping your frame, and replace the nut and washer.  The hard part is removing the stock stand; like Monte says you probably will have to remove the exhaust for that.
