Author Topic: Pushrod tube replacement.  (Read 2143 times)
Offline beemer
  • The Red Tomato!!!
« on: June 02, 2009, 03:34:26 AM »
Iv'e noticed that the pushrod tubes on my R65LS seem to be quite rusty,i guess this is a common thing as they are located under the cylinder and prone to road muck etc,anyway,i was wondering if you have to remove the barrell completly to do this job,or can you get away without taking the piston out, by just pulling the barrell forward so that you can remove the tubes?there isn't any leaks,should i leave them be?what do you think guys,J.
Andy-Gadget
Re: Pushrod tube replacement.
« Reply #1 on: June 02, 2009, 03:42:18 AM »
Motobins lists stainless replacements for the R65.
And yes, the barrel needs to be pulled to change them, IMHO.
Might as well shout it a new set of rings and big end shells at the same time.
Offline BooG
« Reply #2 on: June 02, 2009, 04:29:17 AM »
Personally, I'm of the "if it ain't brock-up, don't fix it" school. Mine are a bit rusty as well. Factor in all the other work you could do at the same time...add up all the time and money you might take...double it: thats what it will take! I did mine last year (pushrod tube seals) and learn't quite alot from taking the jugs off for the first time. What am I saying?
Its an "if you can be bothered" job.
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
« Reply #3 on: June 02, 2009, 07:37:33 AM »
I would leave it until you need to remove the barrels for another reason.
I have the stainless steel ones and they still leak like Bu**ery.  Never had them sealed since they were changed.  Probably have not got the rubbers properly orientated.
If they are really bugging you, how about painting them in situ.  Be gash, and wait till you have a amost empty tank, then lean the bike over onto one of the jugs (on something soft) - degrease them then clean em up with scotch bright and paint with a brush.  He presto.  Job done.  Now you can go out for a ride - after you have done the other side ;D
As you say they are under the bike and get covered in rubbish.
How abot a nice gaudy colour to make them starnd out - or perhaps black or silver is best.
« Last Edit: June 02, 2009, 07:37:58 AM by steve_hawkins »
Offline beemer
  • The Red Tomato!!!
« Reply #4 on: June 02, 2009, 08:16:37 AM »
I know what your saying Steve,i just noticed it and thought,blimey,what if it starts to leak badly while i'm riding along with my girlfriend on the back(don't tell the wife, 8-))iv'e got some bathroom pink in the shed!!!i think i will leave alone till i need to do some other work that involves removing the barrell,have you known of these suddenly causing a bad oil leak?thanks,Julian.
Offline beemer
  • The Red Tomato!!!
« Reply #5 on: June 02, 2009, 08:18:15 AM »
Thanks for the reply,and your right of course!!cheers,Julian.
« Reply #6 on: June 03, 2009, 03:26:30 AM »
They are genrally quite stout and take a lot of rusting through.
It might be advantageous to paint them just to stop them rusting further.
I have not heard of then actually rusting through, more usually the rubbers perish before that happens, and you end up replacing them while doing the rubbers.
Most are covered in oil anyway.
Offline beemer
  • The Red Tomato!!!
« Reply #7 on: June 03, 2009, 05:18:09 AM »
Iv'e just come inside the house Steve after giving them a lick of Hammerite in sliver.so that should do the trick,hot and sunny here in West Wales,i should be out for a ride,but my daughter is home revising for her GCSE exams which start on Friday,so i had better stick around,thanks for your advice,Julian.
