Author Topic: Starting your bike after a few days layoff!!  (Read 2825 times)
Offline beemer
  • The Red Tomato!!!
« on: April 29, 2009, 03:47:22 PM »
I find that starting my bike after a few days layoff can be a pain!!!it seems that i need to leave the fuel tap on for 10-15 minutes so the carbs fill,does anyone have the same problem?is it a common BMW thing?after she's started there isn't a problem if i stop and start again,say,a few hours later,i wish these carbs had "ticklers"like some of the old British bikes,you simply pressed the tickler,the carbs filled,and you could start,anyway,any ideas?thanks,Julian.
Re: Starting your bike after a few days layoff!!
« Reply #1 on: April 29, 2009, 04:00:42 PM »
It's not a common trait among the BMW bikes.
First comment, you need to turn the fuel tap on for an extended time, do you have any after market filters in the fuel system, if so , may want to replace it.
There should be a filter, or strainer element on the fuel line that screws into the bottom of the tank, remove it ,and see if it clogged.
When you have the starting issue, can you smell 'raw' fuel from the exhaust ?
Also I believe you are new to BMW bikes,  no throttle input until the cylinders start firing.
A 'weak' coil can have an effect on starting as well.
Problems with the enrichening circuit in the carb can cause hard
starting also.
« Last Edit: April 29, 2009, 04:01:40 PM by Bob_Roller »
Offline beemer
  • The Red Tomato!!!
« Reply #2 on: April 29, 2009, 04:17:55 PM »
starting also.
No after market fuel filters fitted,i don't see any filter fitted to the tap inside or outside the tank,No there is no smell of raw fuel once she starts up,iv'e had my bike for a year now,always been the same starting her up,i replaced the coil,i had the usual cracomatic problem!,i'm not sure how i would check/adjust the enriching circuit,it just seems like the fuel in the carbs evaporates and once full it's fine,thanks,J.
« Reply #3 on: April 29, 2009, 04:35:26 PM »
where do you keep the bike when not in use ?? the bowls should not evapourate in a few days unless there is a leak ive just had to pull my fuel tap and clear a blockage from the reserve line ...ran out of fuel on the M1 switched to reserve and bugger.... nothing had to get the wife to rescue me with the lawnmower fuel can!!.worth draining the tank for a peep.
Offline beemer
  • The Red Tomato!!!
« Reply #4 on: April 29, 2009, 04:51:13 PM »
It's in the Garage,i checked the tank,and removed the tap but not blockage anywhere,no drips from carbs.
« Reply #5 on: April 29, 2009, 07:13:03 PM »
Here's the shirt for you! You'll need to zoom in on the image.
http://www.cafepress.com/MRROACHSIR.368826268#
 ;D
« Reply #6 on: April 29, 2009, 09:21:20 PM »
If you have a gas tank venting problen (several threads exist on this one) you may end up with a partial vacuum in the fuel tank, which would definitely impede the ability for fuel to flow down to the carbs.
I turn the tap on and watch the fuel gurgle through and completely fill my in-line fuel filter within about 10 seconds.
Try unscrewing your fuel tank cap next time - if things fill up much faster, then your fuel cap is plugged and not venting properly.
« Reply #7 on: April 29, 2009, 09:46:32 PM »
If you pull the hose from the petcock, with something to catch the fuel, does it flow out pretty well?  If so, remove the bowls with the petcock off, raise the float gently to close the float jet, turn the fuel on, then slowly lower the floats until you see how much fuel comes out.
...somebody help me here:  HOW MUCH should flow?  I've never measured it, it just looked like way more than 45 mpg.
If for some reason the fuel is slow to reach the carb ticklers wouldn't help anyway.  And a decent choke is way more useful in cold weather.  My Bonnie will start up first kick, but if it's cold I have to keep jabbing the ticklers until it will run on it's own with a little throttle.  I think it took me almost 20 years to figure that trick out.   :-[
If the fuel flow is good in both carbs then I wonder if the little jet in the bottom of the tube in the bowl is plugged up.  Usually only seems to happen to one carb at a time, resulting in initially running on only one cylinder.
vestandpants
« Reply #8 on: April 30, 2009, 03:28:05 AM »
/agreed nhmaf and ed.
Further to what Bob_r wrote about the strainer in the fuel tap, it is contained in the lower part of the assembly or outlet. When I stripped mine (I have no pics of it tho) it had some debris in there.
also see http://bmwmotorcycletech.info/fuelfltrs&petcocks.htm
« Last Edit: April 30, 2009, 03:48:17 AM by vestandpants »
Offline beemer
  • The Red Tomato!!!
« Reply #9 on: April 30, 2009, 03:57:16 AM »
I will check that thankyou.
Offline beemer
  • The Red Tomato!!!
« Reply #10 on: April 30, 2009, 03:59:21 AM »
 ;D
Smelly finger!!!that's great!!! ;D
Offline beemer
  • The Red Tomato!!!
« Reply #11 on: April 30, 2009, 04:04:43 AM »
The fuel flows fast if i pull the  fuel pipe off,i did check the bowls and they seem fine too,in fact i bent the tang slightly and the carbs started to leak,so i put them back to the original position with new gaskets.
Offline k_enn
« Reply #12 on: April 30, 2009, 03:19:03 PM »
Does the exhaust smell like the bike is running a little rich?  When I've had that problem, it has smelled like it was running rich.  When running rich, as soon as you open the throttle it ends up with too much gas to start.
It it is not too rich, one trick that sometimes works on such "cold" starts is to crank the starter, with the throttle in its closed position, and slowly open the choke lever while cranking.  Sometimes that does the trick in terms getting the right amount of gas into the cylinder.
k_enn
« Last Edit: April 30, 2009, 03:22:01 PM by k_enn »
k_enn
original owner of:
?1982 R65
? 2014 K1300S
Offline beemer
  • The Red Tomato!!!
« Reply #13 on: April 30, 2009, 06:07:47 PM »
k_enn
I will try it,thanks.
Offline beemer
  • The Red Tomato!!!
« Reply #14 on: May 02, 2009, 10:12:53 AM »
I had a in-line filter come today in the post,i put it in and found it didn't fill with fuel!!So,took the tank off and removed the tap,cleaned the whole thing including the built in filter,poked a flexible piece of copper wire throught the vent from the filler to the hole under the tank,re-assembled,re-filled with fuel and the in line filter filled right up!let's see if it evaporates in a couple of days,fingers xcrossed!! ;)
« Last Edit: May 02, 2009, 10:13:43 AM by beemer »
