Author Topic: Crankcase Breather Hoses  (Read 1180 times)
Crossrodes
« on: May 13, 2009, 08:36:17 AM »
The hoses which lead into the air-box in my '79 R65 are shot.  I just checked out some prices to replace the hoses...$20+ for the hoses leading into the air-box and $35 for the main hose.  It seems to me that you should be able to fabricate some hoses for this purpose.  Has anyone done this and what did you do?
Re: Crankcase Breather Hoses
« Reply #1 on: May 13, 2009, 08:57:22 AM »
By hoses are you referring to the suction funnels from the air box to the carbs?  I don't recall any hoses specifically.  See the link to the Max BMW microfiche...http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?mospid=47851..., to confirm.  If it is the suction hoses they are less than $12 each from Max but there are many other sources.
steve_wicks
« Reply #2 on: May 13, 2009, 12:22:49 PM »
Mine are also shot so I'm just going to run a hose from the breather, get a T-piece and feed a hose into each carb intake.
I did think of a straight breather hose with one of thos K&N breather filters, but figured maybe the carbs need a bit of lube ..... am I right in my theory?
« Reply #3 on: May 13, 2009, 12:39:09 PM »
Carbs need no "lubing", the crankcase venting is done there just to have somewhere to get rid of it!  A number of folks either run this to a "catch-can" or to a little K&N filter.
Crossrodes
« Reply #4 on: May 13, 2009, 12:49:33 PM »
Bengt Phorqs I'm refering to items 10, 12 & 13 in this diagram:
http://www.realoem.com/bmw/showparts.do?model=0353&mospid=47850&btnr=11_1712&hg=11&fg=10
Mike
« Reply #5 on: May 13, 2009, 12:59:17 PM »
All three of those hoses, are kind of specific for their usage, I think that with the time and effort involved, it would be easier to just replace them with OEM parts.
« Last Edit: May 13, 2009, 03:39:34 PM by Bob_Roller »
« Reply #6 on: May 13, 2009, 03:08:44 PM »
http://www.realoem.com/bmw/showparts.do?model=0353&mospid=47850&btnr=11_1712&hg=...
Ah, now I see what you mean.  Thanks for the edumacation!
