Author Topic: Silencers?  (Read 1931 times)
Offline beemer
  • The Red Tomato!!!
Silencers?
« on: May 11, 2009, 04:36:36 PM »
Iv'e come across a pair of stanless steel silencers,however they are for a 85 onwards bmw,which i think is around 38mm bore(am i correct here?)as my LS is 35mm,i was wondering if you can buy any adaptors,or has anyone made any?
Re: Silencers?
« Reply #1 on: May 11, 2009, 04:46:00 PM »
you can get them the silencers i bought came with sleeve adaptors for 35 mill with them in or 38 without if you cannot find any just wrap some shim steel around the tail of the pipe and clamp down on that
Re: Silencers?
« Reply #2 on: May 11, 2009, 04:50:11 PM »
ill check my box of bits as i replaced one of the sleeves with about 3inch of stainless steel tube to cover a hole if you have an old numatic vacuum the down pipe fits perfectly 35mm id 38mm od just fit it with abit of exaust sealant and its stainless steel
Offline beemer
  • The Red Tomato!!!
Re: Silencers?
« Reply #3 on: May 11, 2009, 04:59:10 PM »
Thanks for the help Lou,will try and get some tubing tomorrow.
Re: Silencers?
« Reply #4 on: May 12, 2009, 01:09:03 AM »
Beemer, post a pic of what you wind up with.  I have some monoshock mufflers/silencers up in the attic and I had not even thought of putting them on the LS but it really needs 'em...
Re: Silencers?
« Reply #5 on: May 12, 2009, 10:33:08 AM »
These might werk:
http://tinyurl.com/prfjh9
Re: Silencers?
« Reply #6 on: May 12, 2009, 10:56:41 AM »
Lucky you
Ive just found the adaptor that i didnt use ......yours if you want it plus ill send you some stainless tube for the other just Pm me your address and ill stick em in the post
Offline beemer
  • The Red Tomato!!!
Re: Silencers?
« Reply #7 on: May 12, 2009, 05:03:52 PM »
I will do that,i'm getting some S/Steel tubing tomorrow,cheers.
Offline beemer
  • The Red Tomato!!!
Re: Silencers?
« Reply #8 on: May 12, 2009, 05:04:44 PM »
Lucky you
Iv'e sent you a PM lou,many thanks,Julian.
