Author Topic: What AH battery do i need for my 65LS?  (Read 1032 times)
Offline beemer
  • The Red Tomato!!!
« on: May 01, 2009, 09:52:38 AM »
Think it's time for a new battery!!but not sure about the AH i should get,please give me some ideas.thanks.
Re: What AH battery do i need for my 65LS?
« Reply #1 on: May 01, 2009, 11:50:00 AM »
Your choices are going to be limited by the size of the battery, the R65 uses a not so common size battery.
If I'm not mistaken, an 18 AH battery is the largest that will fit, without altering the battery box.
TheLSKid
« Reply #2 on: May 01, 2009, 12:19:44 PM »
These two sealed batteries fit. My Westco worked well for 4 plus years. The second option is a lot cheaper and basically the same as the 20AH Westco. Fits and works as well according to several second hand reports. Will be my next battery.
http://www.westcobattery.com/battery_page.php?bid=6&vid=1&mid=16
http://www.beiterbattery.com/toyo12volt1820ahslabattery.aspx
« Last Edit: May 01, 2009, 12:22:03 PM by TheLSKid »
Offline beemer
  • The Red Tomato!!!
« Reply #3 on: May 01, 2009, 05:13:19 PM »
Thanks for the info :)
