Author Topic: Engine starter cover  (Read 761 times)
ukzknos
« on: April 25, 2009, 04:55:01 AM »
Just a question following my recent engine breather upgrade:
All documentation I read and web articles suggest the starter cover comes off quite easily once the two allen screws are removed.
I had to remove BOTH halves of the clam shell air filter housing to slide the starter cover out!
Any comments welcomed?
vestandpants
Re: Engine starter cover
« Reply #1 on: April 25, 2009, 05:32:56 AM »
Yep, sounds about right mate. It is possible to 'roll' the starter cover off, towards the left pot however i've never managed it with the electrics in the way!
« Reply #2 on: April 25, 2009, 10:41:19 AM »
I pulled the starter cover off my '81 this morning in prep for a timing chain replacement. Air filter cover and filter off, then the two Allen screws. Came away easily. However...
...as my Bings are all shiny and freshly overhauled -plus still sitting on the bench- there was a lot less pieces parts and cables in my way.
Just hold your tongue right and it does come off without stress.
Added: The manual states that it may be necessary to remove ignition coil/s if they interfere with starter cover removal.
PS: Dig the Chuckie eyedrops, Masoon. Funny. Minutiae Moment... Toured the Tabasco factory on Avery Island near New Iberia, Louisiana couple years ago. Tour guide girl -with a way cool Cajun accent- said there biggest foreign buyer is Saudi Arabia. Go figure. They were labeling a production run right then with Japanese-language labels.
« Last Edit: April 25, 2009, 11:41:48 AM by montmil »
« Reply #3 on: April 25, 2009, 11:10:25 AM »
If you still have the cover off, look at the edges where it looks like it was contacting the surrounding areas, and remove a little metal with a file, or sandpaper, and it will come off easier next time.
