Author Topic: Crankcase breather  (Read 2438 times)
ukzknos
Crankcase breather
« on: April 23, 2009, 03:32:53 PM »
Striving constantly to diagnose my low rpm screech I've decided to replace the old type crankcase breather with the later reed type. I know it isn't the cause but the 'turkey gobble' has to go anyway!
Has anyone done this previously and if so, any tips (without buying a specialist tool) for removing the old valve body from the engine casing?
ukzknos
Re: Crankcase breather
« Reply #1 on: April 24, 2009, 02:10:03 PM »
OK, sorted it out this evening!
32mm socket, long self tapper with washer, 10mm spanner and 10mm allen key.
If anyone needs to know in future drop me a line  :)
« Reply #2 on: April 24, 2009, 03:03:46 PM »
If you took a couple of pics as you went along it would make a good "how-to" for the Wiki...
« Last Edit: April 24, 2009, 03:04:40 PM by admin »
ukzknos
« Reply #3 on: April 24, 2009, 04:34:40 PM »
Sorry Justin I didn't know how that worked but I can post a sketch on there illustrating the technique.
Can any member write on the wiki then?
« Reply #4 on: April 24, 2009, 04:41:18 PM »
Yes, all you have to do is register (on the Wiki site) and you will then have authoring priv.
« Last Edit: April 24, 2009, 04:41:52 PM by admin »
« Reply #5 on: April 24, 2009, 06:16:10 PM »
I thought all of the R65's were mfg'd after the factory had switched to the reed-type valve?  No?
And (IMO) the turkey gobbling is just one more quaint trait of these wonderful machines!
« Last Edit: April 24, 2009, 06:17:16 PM by Rob_Valdez_79_R65 »
« Reply #6 on: April 24, 2009, 09:31:19 PM »
As long as you're a PC and not a Mac user >:(  For some reason, even though I'm registered and recognized by the Wiki page, I'm not able to find any entry for posting.   Monte
« Reply #7 on: April 24, 2009, 09:44:40 PM »
Oh, you're one of THEM, eh?   [smiley=Kick.gif] PM me your Wiki username and password and I'll log into it as you and see.
« Reply #8 on: April 24, 2009, 10:08:55 PM »
{rubbing hands together in anticipation}  I look forward to a couple of really interesting articles by "Monte."
