Author Topic: steering bearings  (Read 1494 times)
hahn
steering bearings
« on: April 22, 2009, 08:40:39 AM »
I NEED TO REPLACE MY STEERING BEARINGS,  DOES ANYBODY KNOW THE PART NUMBER FOR A TIMKIN??  THANKS HAHN
Online Bob_Roller
Re: steering bearings
« Reply #1 on: April 22, 2009, 10:08:44 AM »
I don't have a Timken number, but the size of the bearing is 28x52x16.
Should be able to cross the size on a Timken catalog.
« Last Edit: April 22, 2009, 10:11:26 AM by Bob_Roller »
« Reply #2 on: April 22, 2009, 10:16:51 AM »
Most of the OEM bearings are FAG.  I believe the number is FAG 32028.  This can be crossed to an SKF or Timken number easily by your bearing supplier...
« Reply #3 on: April 22, 2009, 04:29:14 PM »
If you pull the old bearing off the ref number should be stamped on the edge of the outer race any good quality manufacturer should be able to match it, I stripped and re-greased mine recently and they look like a fairly standard bearing to me
drewboid
« Reply #4 on: April 23, 2009, 07:41:10 AM »
You will probably need Ed Corn's steering bearing puller:
http://www.cycleworks.net/tools_chassis_wheels.htm
Without it the outer race is very difficult to remove.  YMMV
