Author Topic: Steering bearing lube!!  (Read 1515 times)
Offline beemer
  • The Red Tomato!!!
« on: April 14, 2009, 09:12:34 AM »
Finally got down to doing my R65LS steering bearing lube job this morning,all went very well indeed thanks to the info in the R65 Technical FAQ/Procedures,it's great to have the input from somebody who has done the job already.many thanks!! :)
hahn
Re: Steering bearing lube!!
« Reply #1 on: April 16, 2009, 11:12:42 AM »
so how do you do it???           hahn
« Reply #2 on: April 16, 2009, 12:29:04 PM »
The post mentions the "R65 Technical FAQ/Procedures" section so that might be a good place to look...
« Reply #3 on: April 16, 2009, 02:44:04 PM »
This thread should cover most questions on this topic and give you some good tips/procedure:
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1175535024/27#27
Offline beemer
  • The Red Tomato!!!
« Reply #4 on: April 17, 2009, 04:54:07 PM »
Here,follow it and you shoudn't go wrong!!
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1189357717
« Reply #5 on: April 18, 2009, 12:02:17 PM »
Honest...it's not that hard, just time consuming the first time around.
« Reply #6 on: April 18, 2009, 12:10:24 PM »
Is anybody going to put this steering head bearing lube post/faq into the Wiki?  Or, if Sue will zip up the pictures, e-mail them to me, and say where to put them in the text I'll do it when/if I get time...
« Last Edit: April 18, 2009, 12:15:36 PM by admin »
Offline beemer
  • The Red Tomato!!!
« Reply #7 on: April 18, 2009, 07:47:57 PM »
I was going to do it before i put the bike up for winter,and i tested the steering movement when the weather was really cold,the steering became very stiff with the drop in temp,but now it falls to either side real easy,thanks for your article,i didn't even need to look at my manual,just follwed the instructions. :)
